issues with aftermarket hu
Old May 26, 2006 | 06:40 PM
fred's Avatar
ok. i have a 90 gxe, which is a pile, so it is being the donor for parts for my sisters 91. the 90 had bose, the 91 does not. my pioneer headunit works in the 90, but when i take it and try to plug it into the 91, it doesnt work. but hte funny thing is, it worked right away, when i was testing it, but then when i mounted it, it doesnt work anymore. i tried putting it back in the 90, and it works in there. i know that the 91 the previous owner had their radio stolen. but mine was working for awhile in there, so it shouldnt be an issue. suggestions?
Old May 26, 2006 | 06:43 PM
AscendantMax's Avatar
did you check connections to the harness? if it tested fine when it was still out of the dash, but stopped when everything is in...i'm guessing it's a lose connection somewhere.
Old May 26, 2006 | 06:44 PM
fred's Avatar
like from the hu's harness to the cars? yeah i redid every single one
Old May 26, 2006 | 08:08 PM
djfrestyl's Avatar
Suspension Yoda
chassis ground....?
Old May 27, 2006 | 01:53 PM
fred's Avatar
it was working. and i didnt change anything. but now it doesnt. another thing i have noticed that started happening is the seatbelts wont move unless the ignition is switched to on.
Old May 27, 2006 | 07:04 PM
fred's Avatar
ha i figured out what was wrong. there was a fuse blown...the "Electron BAT" fuse. and now the seatbelts work properly and the keyless entry. now everything works. wonder what blew it...and what it is for....
Old May 27, 2006 | 07:14 PM
probably accidently shorted it during the install. good thing they changed the automatic seatbelts to the traditional manual one. that thing got annoying at times.
Old May 27, 2006 | 07:28 PM
fred's Avatar
yeah i must have. automatic seatbelts ftL!
Old May 28, 2006 | 06:59 AM
1996blackmax's Avatar
I did like the heated outside mirrors and ability to switch the transmmision shifting on my 92 GXE .
Old May 29, 2006 | 12:19 PM
rachidfunaki's Avatar
sorry to piggyback!
hey sorry to sorta piggyback on ya but i'm kinda having the same problem with my 90 non bose. i put my perfectly working pioneer from my paseo (RIP) in it and it worked for a while but now my seatbelts won't work until i start the car and hit the gas a little. plus all the little lights don't work either and the power locks and windows! is it my ground? I have the radio grounded to the top left bolt in the radio chassis, should i ground it somewhere else? please please help!
Old May 29, 2006 | 12:42 PM
JEXTEL's Avatar
check the fuses...There usually a 20amp
Old May 29, 2006 | 09:18 PM
fred's Avatar
check the fuse that blew on me: its in one of the posts higher up. it the third or fourth fuse from the bottom on the left side. for me it was a 10 amp.
Old May 29, 2006 | 11:03 PM
i checked all the fuses but nothing came up blown this is really a problem i'm gonna try and put my factory back in the morning to see if that fixes it
Old May 30, 2006 | 11:29 PM
ok everything works perfectly with the stock hooked up and the panisonic works fine in my wifes car (2000 civic). i hooked up stereos amps and the works in both of my other cars and my wifes car with no prob. the ground from the stock radio is loose and i didn't connect the antenna (new hidden antenna i ran the wire with the rcas to the trunk) could either of these be the problem? please help me! (btw she had the honda when i met her and yes i still married her anyway)
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
gustavison
Oct 4, 2015 06:50 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
