When i close the trunk the alarm goes off!!!!!
Alright i have the viper 791 and when the car is armed and i use the remote to open the trunk then i close the trunk and the alarm goes off... How can i fix this..
Isn't there a diode for this? Like Don said, there is supposed to be a trunk trigger to alert the brain module to alarm the car when the trunk is opened, not closed (only triggers the alarm one way, not the other). When I had a Viper alarm, the installer tapped the trunk trigger wire to the trunk switch that turns on the lamp. Also, it's not a good idea to tap into the light bulb circuit when the bulb turns on, because you can get false alarms from the bulb being burned out. I would check to see how your trunk trigger is wired up and start from there.
REDinLV
08-15-2024 12:30 AM
litch
123
01-04-2024 07:01 PM
mkaresh
03-12-2018 06:48 PM
