I need Bass
I need Bass
I had a 15inch eclipse titanium in my 4th gen. Now I want some bass in my 5th. I was thinking I would just get an amp that will be able to be run with line level inputs from the wiring of the stock bose sub and a nice sub to go along with it, an 8in to fit in the stock location. Does anyone have a suggestion of a good sounding 8in sub and amp combo that will run off of stock wiring for the 5th gen maxima with bose? Thanks for your help.
You can't use the wiring from the bose system. You have to use an output converter to be able to get some signal cables. Then you can put the sub in the stock location if it will fit, but you will have to plug it into the amp using seperate speaker wire.
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
Cincy94Max
Feb 23, 2001 05:57 AM
