system problem
Old Nov 13, 2006 | 06:06 AM
dahman45's Avatar
system problem
i was playing my system loud the other day and my sub started to cut in and out. so i turned it down and it plays at low volume. Then i was driving at night and turned it up a little and all my lights inside where dimming like crazy, so i got a yellow top battery and have the same problem.....i think its my alternator? any other opinions
Old Nov 13, 2006 | 07:00 AM
opanick's Avatar
maybe a capacitor would help out????
Old Nov 13, 2006 | 07:23 AM
dahman45's Avatar
yeah i have some that i dont have hooked up ill have to try that but its wierd taht it just happened to me all of a sudden. bc ive played my system loud like tht b4 with no problems
Old Nov 13, 2006 | 07:33 AM
Wil's95SE's Avatar
我爱台湾
Skip the capacitor, have your alternator tested, and do the BIG 3. If your alternator checks out you may have some other type of electrical short somewhere. Make sure all your grounds are good and if not clean them up. Check your amp wiring as well.
Old Nov 13, 2006 | 11:22 AM
DcMaN's Avatar
arm****! get back in ct lol. Check the sub with a multimeter make sure it reads the correct ohm, i highly doubt its the alternator. Check the voltage of the battery see if its overcharging. Do the lights dimm without the system on ? Does it seem like there is a lack of bass coming from the sub at higher volumes before it starts to cut out ?
Old Nov 13, 2006 | 11:29 AM
AscendantMax's Avatar
i'm assuming it's the alternator as well...since the problem seem to be gradually getting worse. have the alternator check out to see if it's putting out sufficient voltage.
Old Nov 14, 2006 | 11:02 AM
03SE2HEAR's Avatar
Sounds like it could be an alternator issue. I'd have that checked out by an auto parts store or just stop in to Soundwaves of St.Augustine and ask them if they could take a peek at the electrical system.
1765 Tree Blvd.
St. Augustine, FL 32086
(904) 829-9495
Old Nov 14, 2006 | 11:32 AM
Pearl96Max's Avatar
I tend to get a bit irritable
More importantly...Amperage.
Old Nov 14, 2006 | 01:07 PM
that too....
Old Nov 14, 2006 | 01:59 PM
markd248's Avatar
get that checked out as quickly as possible. 4th gens had a recall for their alternator. i believe there have been cases of the alternator catching fire and basically the whole car went with it. probably worth goin to the stealership for...
Old Nov 14, 2006 | 07:38 PM
Darius's Avatar
I have the same dimming problem... except recently its gotten worse. I'll be stopped or rolling very slowly and all the electronics in the car will turn off and back on (radar detector and deck reset themselves). This happens randomly... on some drives not at all, on some it will happen 1 or 2 times. Do you think this is the alternator as well or a short somewhere in my system?
Old Nov 14, 2006 | 11:32 PM
cpuguy06's Avatar
Ya I got a problem to. I have a 200w amp for my front speakers, and a 400 w amp for my sub. Its driving two MTX Roadthunder rt10-04s 200wRMS per sub. my interior lights are dimming..WHY? There are people here who have way more power than that and their lights inside are just barely dimming. Also are power dips hard on the good ol HIDs?
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
carid
Sep 9, 2015 05:06 AM
slowlifer
Sep 8, 2015 05:53 AM
