Subwoofer blown help
Old Jan 7, 2007 | 03:18 PM
machinehead131's Avatar
Hey i've blown 2 different 10s now with my current setup....
i am moving on to 2 12 kicker comp cvrs....
will this amp do the trick because its what i got ... its a Kenwood KAC-8152D
I am just going to buy a sealed box and build a new amp rack.
Will this amp be good for 2 kicker cvr 400rms per sub single voice coil
any suggestions on other subwoofers in same price range are welcome..
thanks
Old Jan 7, 2007 | 03:31 PM
AscendantMax's Avatar
i think you should address the problem at hand here (blowing two subs) before buying any more subs. how are the gains set? how were the subs wired?
Old Jan 7, 2007 | 03:37 PM
the voltage was matched to deck
subs were wired at 4 ohm
I don't know what im doing wrong bass boost was only half way up
My buddy loaned me his extra CVR and its great for now so thats what i was thinking of doing..
Old Jan 7, 2007 | 03:48 PM
nismos14's Avatar
§è~® f®ÈÄk
I wonder if you weren't pushing your amp into clipping, what was the actually gain setting to? What percentage? 50% up? 75%?
Old Jan 7, 2007 | 04:49 PM
it was at 50%
i need to also order this equip soon so i can set it up the right way now but i need approval.
Old Jan 7, 2007 | 05:15 PM
nismos14's Avatar
§è~® f®ÈÄk
Take the money you were gonna spend on one cvr and buy one higher quality midline sub.
Old Jan 7, 2007 | 05:30 PM
ICEMAN76's Avatar
That sounds like a good idea. B4 u buy anything though u should really try to figure out what is causing ur subs to blow. U don't want it to happen a 3rd time.
Old Jan 7, 2007 | 05:35 PM
1996blackmax's Avatar
Did you turn up the boost after setting the gains?
Old Jan 8, 2007 | 04:52 AM
well i am getting a new box for starters...whats a good midline sub.
Old Jan 8, 2007 | 10:48 AM
nismos14's Avatar
§è~® f®ÈÄk
What is your budget?
Old Jan 8, 2007 | 02:15 PM
for box and materials for a new amp rack plus sub is like 300
Old Jan 9, 2007 | 04:52 AM
clear-mind@180's Avatar
I'm with Iceman here - I'd figure out your issue before you drop more coin... The blown subs are not likely an indication of the quality of the subs themselves or the amps - it's more likely your install or your settings. If you were over-driving the subs (eg, too much constant power **remember - a sub has 2 ratings, peak and constant capabilities**) then you may just need to back down the gains or get beefier subs. I'd wonder, though, if you may have had a bad connection somewhere within the box. I've always built my own boxes so I had total control over that (and, if you have an amp that can take a 2 ohm load, wire those babies in parallel). One last note, keep in mind that a sealed box *will* give you tighter, punchier bass but at a lower overall dB - there's a reason that at soundoffs, all the comp. systems are usually ported enclosures... You'll get more "volume" out of a ported box but it will (to me at least) be sloppier sounding and, if you listen to anything other than rap/dance you'll like the sealed ones better. But - the sealed enclosures *DO* take more power to drive (because, in effect, you're powering the compression and decompression of the sealed volume of air in the box).
Old Jan 9, 2007 | 07:27 PM
i still am stumped as to what it is, i think it was the box i built, but does anyone have advice as to how to build a good sealed enclosure for a specific sub, hopefully you guys can run me through the whole setup so i dont blow another sub this time, but ive been trying to figure it out and am still stumped.
Old Jan 10, 2007 | 05:45 AM
Each sub's will have different characteristics, and thus require a different enclosure... Check the mfg website or the box and see what box volume they recommend for the type of enclosure you want (sealed or ported). Sealed generally require less space and produce tighter bass response but with higher power demands. Build the box out of MDF or Ultra-Board and do the math to get the enclosure to the right volume. Also, I always siliconed the snot out of the insides of the boxes, and even used rubber gaskets between the sub basket and the boxes to ensure a VERY air-tight enclosure. If you can push (gently) on the sub's cone and get it to push in (as in, air must be coming *out* somewhere) - you didn't seal well enough.
Old Jan 10, 2007 | 10:06 AM
^ well you can still push the cone in a little bit even if the entire enclosure was air tight. air can compress.
Old Jan 10, 2007 | 02:27 PM
any recommendations on subs...?
Old Jan 10, 2007 | 04:43 PM
slickrick's Avatar
Funky pups...
Old Jan 10, 2007 | 05:16 PM
DcMaN's Avatar
LOL @ bassboost only on 50% .
Ok heres a little lesson with bassboost.(Granted i barely use bassboost maybe 5% or less). If your sub is not tuned right ie(input sensitivity) being turned up more than it should be then it will cause clipping. All bass boost does is amplify distortion, and making the distortion more audible, it may appear it makes the sub a little louder but in the long run its just not worth i. So if your sub is distorting and you turn up bassboost you run a high risk of blowing the sub because of the increase in distortion.
Old Jan 10, 2007 | 06:12 PM
Hexon's Avatar
should you adjust bass boost and then adjust the gains?
Old Jan 11, 2007 | 08:10 AM
I'm not so sure I agree that "Bass Boost" is a distortion booster, although I definitely agree that increased distortion is usually the outcome... The bass boost takes the lower end of the frequency range and essentially increases the output at those frequencies - akin to raising the level on the lower 3 frequencies on a 7-band EQ. 50% *IS* extreme - and I agree that if your box is tuned properly and if your car is setup properly, you ought not be using bass boost. If your other speakers can achieve the 70+(ish) frequencies and your subs can respond up to that 70-80 range, your "bass-boost" should be achieved with a properly set gain on your sub amp(s).
Old Jan 11, 2007 | 08:20 AM
slickrick's Avatar
no SQ user uses BB...end of story.
Old Jan 11, 2007 | 06:54 PM
i still need help deciding what to purchase for the new, properly done setup
Old Jan 13, 2007 | 03:21 PM
now gs's Avatar
buy one 12 or 13 w6, you are overpowering cheap speakers that's the reason they are blowing up.
Old Jan 13, 2007 | 04:12 PM
MR.Large's Avatar
It is alright if you have an amp that is too powerful for your sub tho, then you leave the gains down and the amp will run more efficent. So that is not a bad thing. I say look into other problems like that amp its self. if you start blowing a lot of subs with it there is a good chance that the amp is starting to deliver to much voltage to your subs. A classic sign of an amp that is having a failing powersupply/mosfet problem. Find the problem first
Old Jan 13, 2007 | 09:26 PM
how would i trouble shoot to see what the problem is?
i also dont want to go JL because of price...
Old Jan 14, 2007 | 02:49 PM
AnDyMaN's Avatar
maybe a voltmeter?
Old Jan 14, 2007 | 06:27 PM
what would i check with the voltmeter?
Old Jan 18, 2007 | 07:27 PM
uP? 10char
Old Jan 18, 2007 | 07:42 PM
nismos14's Avatar
§è~® f®ÈÄk
Use the voltmeter to test the resistance across the coils. Move the cone in and out see if the resistance ever drops to 0, if it does, the sub is blown.
Old Feb 8, 2007 | 09:02 AM
ok subs blown....i want to either buy or a build a custom box for either 2 10's or a higher output 12....suggestions?
Old Feb 8, 2007 | 09:13 AM
slickrick's Avatar
budget please...
Old Feb 11, 2007 | 12:37 PM
budget probably around 400-500
Old Feb 11, 2007 | 04:03 PM
http://www.ddaudio.com/dd/caraudio/w...p?series=9500f
9512 in a ported box, fed 1000kw will make your head hurt.
Old Feb 12, 2007 | 09:01 AM
any other suggestions....btw i have a Kenwood KAC-9102D to power these subs...i also wanted to go sealed because i listen to a lot of rock music...
sliptap
Sep 30, 2015 05:57 AM
homewrecker
Sep 24, 2015 07:01 PM
TxBroncosFan
Sep 21, 2015 06:54 PM
