rf noise please step in and help
Old Jan 9, 2007 | 07:10 AM
ALSOUSA99MAXIMA's Avatar
All right here it goes i just installed a screen and a ps2, at first i was running a power inverter, and i was getting no interference, i hard wired it yesterday and now i am getting interference, i am only getting interference when the playstation is on and the deck is in aux. any ideas?
I was thinking sh!tty ground?
Old Jan 9, 2007 | 07:19 AM
BUmp>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Old Jan 9, 2007 | 07:37 AM
maxchef's Avatar
Yes Sir.....it sounds to me like it would be a ground issue. Where is the inverter grounded?...the screen?....it is not wise in my expirence to ground mulitple things in a MAX all at the same point.
Chef
Old Jan 9, 2007 | 07:50 AM
clear-mind@180's Avatar
Agreed with previous reply - "star" grounds, as the multiple grounds to a single location used to be called, are generally a bad idea... You almost always end up with a "ground loop" (I'd explain that one but I'll save everybody the snoozer and just say - ground them to separate, but good, locations. PS - testing good grounds = testing the resistance (ohm load) between the negative terminal on the battery and the actual attempted ground location... look for your lowest ohm load.
Old Jan 9, 2007 | 07:55 AM
thanx alot guys i will post up the conclusion.
user 11122324
42
Jul 18, 2022 03:35 PM
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
