Aftermarket headunit install w/ Bose
Old 01-13-2007 | 10:03 AM
Maxi98se's Avatar
I am trying to install the microvision tv with an aftermarket headunit. My max originally came with the Bose system. I have the Metra 70-7551 Harness I have everything hooked up right i believe and I still cannot get any sound ! If any one can help id appreciate it thanks in advance
Old 01-13-2007 | 03:07 PM
nismos14's Avatar
§è~® f®ÈÄk
Is your antenna plugged in? Is the remote wire connected to the amp turn on for hte bose?
Old 01-13-2007 | 04:10 PM
now gs's Avatar
are you running just the aftermarket deck, no amps to speakers?
Old 01-13-2007 | 06:11 PM
Maxi98se's Avatar
I am running just the aftermarket deck this is the wiring harness i am using...
i found this pic on the web so you can see what it looks like http://www.installer.com/item/displa...php?it=70-7551 everything else is stock bose...
Old 01-15-2007 | 07:52 AM
PhillyDonut's Avatar
Are you trying to use an aftermarket Headunit with Bose speakers?
If so, you would need a ROEM-NIS2 (plugs into factory harness) or OEA4 if you want to be cheap and don't mind splicing a couple of wires.
I've been using a ROEM-NIS2 for over 2 years without a problem and the Bose speakers sound much better.
Old 01-15-2007 | 08:13 AM
Pearl96Max's Avatar
I tend to get a bit irritable
thats actually false. The harness he has works perfectly fine. My best guess would be that the OEM amp is not powered up.
Old 01-15-2007 | 08:39 AM
I stand corrected!
For the OP:
See link from car audio FAQ:
http://forums.maxima.org/showthread.php?t=60393&page=2
Putting an aftermarket radio on stock bose speakers: This applies to any generation maxima, and #4 applies to 4th gen and up.
Your factory Bose head unit sends an unamplified audio signal to the Bose amps. So you want to replicate this as close as possible for the best sq, in theory. There are a few options:
1) You can wire it up as a normal head unit without any Bose adapters, and have a small risk of burning up the Bose amp(s).
2) You can buy the $50 PAC or Scosche adapter, such as the one here
4th gen and up: http://www.crutchfield.com/S-7pnyu0E...51&I=142C4NN03
3rd gen: http://www.crutchfield.com/S-7pnyu0E...51&I=142C4NN02
3) You can wire the deck's preouts to the wiring harness in the dash, which will send an unamplified signal to the Bose amps. You have front and rear preouts. Each of those has a left (white) and right (red). So youd plug in RCA ends to the front and rear preouts, leaving a few inches of wire for you to play with. For the front left RCA, there will be 2 single wires inside it. Wire those to white and white/black. The front right, wire those to gray and gray/black. Do the same for the rears, Rear left will be the green and green/black, and Rear right will be purple and purple/black.
4) You can buy the Metra 70-7551 for 4th gen and up, or 70-1764 for 3rd gen (which is usually hard to find locally) which will already have all of Step #3 above done for you, so you can just plug stuff in.
http://www.metraonline.com/i/METRAHANDOUT_2005.pdf
Page 25 of 36 is a pic of both the Metra 70-7551 and 70-1764.
If you need your radio installed asap, the most cost effective way is Step #3. But if you can find the 70-7551 harness, or have time to order it online, it will probably save you some headache. Those are the easiest, most cost effective methods of this installation.
Caution: If the voltage of your preouts isnt a decent amount, you might want to avoid steps 3 or 4 and go with step 2. Low voltage preouts combined with step 3 or 4 will equate to your Bose speakers not getting loud once installed.
Check your preouts and amp?.
Old 01-15-2007 | 08:48 AM
Pearl96Max's Avatar
Im well aware of what the FAQs have listed. What I said was false was your statement... "If so, you would need a ROEM-NIS2"
Old 01-15-2007 | 08:58 AM
Don - that FAQ quote/link/info was for the OP. I am in agreement with and that "I stand corrected!" in the heading of my post was meant for quote of your response.
Edited.
Old 01-15-2007 | 08:59 AM
kpr10is's Avatar
At first, I read his most recent post the same way you did and was confused too, but then I saw the title of his post saying "I stand corrected", so I think he now understands and was just linking to my Car Audio FAQ post for clarification.
On topic...yeah, likely culprit is the factory amp's remote wire.
edit: he beat me to it anyway.
Old 01-15-2007 | 09:00 AM
Pearl96Max's Avatar
Gotcha .
Old 01-15-2007 | 04:06 PM
max95q's Avatar
I read the faq about Step # 3 and it has a caution. What is considered a decent amount of voltage for the preouts? I would like to put in my old Pioneer premier radio from 99. Is it needing at least 5 volts or will 2v work just fine?
Old 01-15-2007 | 04:30 PM
maxima_tuned's Avatar
Where can I get a microvision screen from?
Old 01-20-2007 | 09:11 AM
max95q's Avatar
Bump for an answer to my question about the preouts
Old 02-06-2007 | 05:00 PM
Maxi98se's Avatar
bringing my thread back from the dead with the wiring harness im using what do i hook up the amp turn on wire to ????? Do i ground it or hook it up with the power antenna tia!
Old 02-06-2007 | 07:32 PM
nismopc's Avatar
DON'T GROUND IT!
Remote turn on needs a +12 volt signal. You should be able to use the antenna lead. Works the same as remote amp turn on.
Old 02-06-2007 | 07:34 PM
Pearl96Max's Avatar
Depends on the type of HU, but definately do Not ground it.
Old 02-07-2007 | 07:09 AM
Law520's Avatar
Can Best Buy or Circuit City install an aftermarket head unit successfully on an 04 Max w/ Nav and Bose without foulin it up?
Old 02-07-2007 | 07:59 AM
Pearl96Max's Avatar
Thats questionable. Im gonna venture a guess and say no though. Really hit or miss with each location.
Old 02-07-2007 | 08:27 AM
nismos14's Avatar
§è~® f®ÈÄk
Agreed .
Old 03-15-2007 | 08:08 PM
thinfine's Avatar
I'm glad that I saw this post. Best Buy quoted me labor costs of about $350 to install a basic HU that use the Bose factory speakers in my Max. Do you have recommendations on who could do this without mucking it up?
Old 03-15-2007 | 08:14 PM
nismos14's Avatar
§è~® f®ÈÄk
Where are you located, that'll help determine who can do it from this forum as well
Old 03-17-2007 | 12:50 PM
00MaxSE's Avatar
Pointy Elbows
Which hu did you go with? I want to swap out my BOSE hu this spring so I can get better sound and hook an ipod up to it.
Old 03-20-2007 | 03:10 PM
thinfine's Avatar
I'm in Rockville, MD.
6spd4dsc
05-09-2022 01:30 PM
MaxLife17
06-27-2019 02:37 PM
MaxLife17
09-08-2015 03:36 PM
Johnny9595
09-03-2015 06:18 AM
A32goldylocks
09-02-2015 07:39 AM
