****ty bass
Old Jan 19, 2007 | 07:51 PM
97NisMaxSE's Avatar
****ty bass
i just hooked up my brand new Pioneer DEH-5800MP after having a line level converter before, for my amp. so i hooked my rca's up to amp output on the HU and it sounds terrible! I have adjusted every audio setting and i have no idea why it sounds so bad. Anyone else have this problem or any solutions?
Old Jan 19, 2007 | 07:58 PM
DcMaN's Avatar
re-adjust the gains on the amp your input sensitivity is probably set too high, as well as bassboost.
Old Jan 19, 2007 | 08:48 PM
freshv6power's Avatar
I have the 4800MP and the subwoofer output polarity had to be reversed. It sounds terrible when set to normal. The easiest way to do this is to swap the rca cords at the amp.
The other way (which is the way I have it done) is to set it at the headunit. I don't know if the faceplates are the same but to change the polarity you hit the sw button and then hit the left or right button. It should show SUB W:REV or if it's already set to reverse change it to normal SUB W:NOR.
Old Jan 19, 2007 | 08:57 PM
nismos14's Avatar
§è~® f®ÈÄk
Does the 5800 have subwoofer control?
Old Jan 20, 2007 | 08:24 AM
97NisMaxSE's Avatar
yea it does. thanks for the input its kinda cold out now but i will go out later and try the gains and see what the reversing does!
Old Jan 20, 2007 | 11:48 AM
Pearl96Max's Avatar
I tend to get a bit irritable
reversing/swapping RCAs doesnt change the polarity. An RCA has a postivie (signal) and a negative (shielding/grounding). If you swap left and right it has no effect on phasing.
Old Jan 21, 2007 | 06:48 AM
Good to know. How about swapping the wires going to the sub?
Old Jan 21, 2007 | 07:48 AM
nismos14's Avatar
§è~® f®ÈÄk
Swapping the actual speaker wires is the only way.
Old Jan 21, 2007 | 09:08 AM
Pearl96Max's Avatar
that would do it.
Mar 12, 2020 12:06 AM
vybz05
Dec 10, 2015 07:38 PM
popdedop
Sep 11, 2015 11:17 AM
Cincy94Max
Feb 23, 2001 05:57 AM
Nick97SE
Dec 16, 2000 02:52 PM
