Amp Clipping
Old Apr 21, 2007 | 06:59 PM
03MAXTNR's Avatar
Amp Clipping
I just hooked up my amp to my stock headunit using an adjustable line output converter which i tapped from my rear speakers. Now the amp is clipping. I have stock speakers. I was getting ready to install my component speakers but figured i should address this issue before going any further. It doesnt matter what setting i set the amp to wether its flat,hp,lp mode it still clips. What should i do to get good signal and no clipping?
Old Apr 24, 2007 | 05:24 AM
03MAXTNR's Avatar
can anyone help me
Old Apr 24, 2007 | 05:28 AM
DcMaN's Avatar
turn the gain (input sensitivity down), and double check your woofer wiring.
Old Apr 24, 2007 | 09:50 AM
filtor1's Avatar
What he said. ^^^^ Let us know what you find. Oh, and turn the bass boost to -0 if the amp has this option, in addition to the above post.
Old Apr 27, 2007 | 08:51 PM
03MAXTNR's Avatar
im going to work on this tomorrow. Ill let you know what the outcome is.
Old Sep 19, 2007 | 03:50 PM
spcboyd's Avatar
Use a dmm and set your gain a little more safely
Old Sep 19, 2007 | 03:56 PM
spark plugs.'s Avatar
Hi, I drive a Maxima.
you probably have the gain on the line output converter and amp set too high. set with the gains on both and move up gradually.
i'd recommend learning how to use a multimeter to properly set the gains
Old Sep 19, 2007 | 05:28 PM
svojs's Avatar
Yeah, lower the input signal level of the amp.
Old Sep 19, 2007 | 05:59 PM
arkainshadow's Avatar
what amp are you using? chanses are if your pumping 60 rms or more to stock speakers (arnt they rated like 20rms) your ganna clip the speakers.
Old Sep 19, 2007 | 08:34 PM
WhiteA32's Avatar
Someone got the link to the dmm guide to tuning
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
