in-dash cd changer install help
Old Jul 16, 2001 | 11:14 AM
Speebs's Avatar
I aim to misbehave.
I recently acquired a Blaupunkt 5-disc in-dash cd changer that I would like to hook up to my Blaupunkt Alaska head unit. The receiver does not supply the changer with power, though, so I have to hook up the supplied adapter cord. I'm inexperienced (but not a complete moron as these things go)... can someone please look at the diagram in the following pdf (bottom of page 15) and tell me where the wires are supposed to go (in fig. 1)?? Do I have to splice the wire from my lighter or what? Thanks in advance.
http://www.blaupunktusa.com/pdfs/changers/IDC_A09.pdf
Speebs
Old Jul 16, 2001 | 03:38 PM
jashick's Avatar
Speebs
If your receiver does not have the pin 15, use the adapter provided to supply 12V. Hook up the fused end to a continual 12V power source and the other end to chassis ground. The 12V side needs to go to the battery or any unswitched 12V line. The lighter (I think) is switched... so you may want to find another line.
By switched, it's referring to turning off with ignition.
Your HU should have one switched and one permanent 12V line so look for that (you can find it in your HU operating/installation instructions).
Old Jul 16, 2001 | 04:09 PM
Speebs's Avatar
I aim to misbehave.
Excellent, thank you very much. If I connect the +12V to a line from the HU, can I also connect the ground wire to a ground from the HU?
Old Jul 16, 2001 | 04:55 PM
jashick's Avatar
On your Alaska HU, the permanent 12V is the yellow wire.
Since the permanent 12V only keeps the memory alive (time and presets), the thin wire of the factory harness should be adequate in delivering enough current for both units.
You can connect the ground to the HU ground if you want.
Old Jul 16, 2001 | 07:21 PM
Speebs's Avatar
I aim to misbehave.
Thank you for your help, jashik.. I did that and it works perfectly. Now I need to get some good speakers and maybe an amp/sub when I win the lottery
Old Jul 16, 2001 | 09:07 PM
jashick's Avatar
Good job.
Enjoy the tunes.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
