Problem with my friends system
Old Jun 29, 2007 | 08:28 AM
WhiteA32's Avatar
I installed a subs into my cousins car a in January, no problems during the install.
About 2 months ago he told me he had a protection light, so I went over and checked everything out and it looked all good. So he called up crutchfield and he got a new amp, I assumed the amp was bad.
New amp, installed it, and same thing. So I checked the fuse at the battery and that was blown, so we got a new fuse, and fuse holder. It worked, the subs were playing.
2 weeks ago I get a call from him again about the subs not working, so I check it out, the fuses are all good. Now I am not sure at all why the amp stays in protection mode. We check all the wires, everywhere. And the amp i still in protection mode.
Not sure what to do?
You guys are going to laugh but this are his specs
MTX Thunder 10's - 2 of them
Visonik 400 WRMS amp
Some Sony HU
The ground is good and so is the power.
Old Jun 29, 2007 | 08:51 AM
djfrestyl's Avatar
Suspension Yoda
Get a meter and start testing wires.
Old Jun 29, 2007 | 09:39 PM
WhiteA32's Avatar
I did that.
I tested the Power wire, and the output coming out from the amp to go to the subs.
The power wire checks, there is no output coming out of the amp.
I am not 100% sure how to test the RCA cables
Old Jul 3, 2007 | 04:56 PM
DcMaN's Avatar
check the ohmload of the woofers, make sure the final impediance is the correct impediance. Seems like one of the woofers is cooked, and the other is giving off a impediance the amp can't handle. Also Unplug the speaker wire(s) from the amp and then turn it on see if it still goes into protection...
Old Jul 3, 2007 | 06:44 PM
WhiteA32's Avatar
Oooooo Good idea...
I remember checking to see if the sub could move in and out and they were, would they still move if they were cooked? and when I checked them they made a faint noise every few mins....
but yea ill check that when he comes back from vaca
Old Jul 3, 2007 | 06:55 PM
AscendantMax's Avatar
test the resistance of the sub. simple way to see if the coil is bad or not.
Old Jul 3, 2007 | 07:06 PM
mendon99's Avatar
tastey wheat
unplug the RCAs while the amp is on, and see if it goes out of protection. Definately check your subs/speakers with a DMM to see if a speaker is shorted out somewhere...
did he change anything recently?
Old Jul 4, 2007 | 05:12 AM
WhiteA32's Avatar
No, not that I know of.
One more thing how do you check to see if the subs are blown, I have a MM I just don't know where to connect it...
MaxLife17
Sep 8, 2015 02:36 PM
Maxboy23
Sep 4, 2015 06:04 PM
Wareagle92
Sep 3, 2015 07:18 PM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
