Dynomat installation??
Old Aug 1, 2001 | 07:33 PM
khrfadz's Avatar
i want to know if anyone here has dynomatted their trunk themselves. i want to know if its a difficult and long process. my trunk rattles like a **** and i would like for the trunk to stop rattlin. also other than the trunk whereelse can u apply the dynamat???
Old Aug 1, 2001 | 08:25 PM
Whitemax's Avatar
Disco Biscuit
Well, its not hard at all. But it is time consuming, and tiring. Just make sure you clean all the metal with alcohol first, or the dynamat wont stick very well. I would do the trunk, the trunk lid, the rear deck in the cabin, and anywhere else you hear rattles coming from. The plastic pillars in the 4 corners of the cabin are a good source of rattles. It is worth it, it is very simple to do, and very rewarding. Just take your time, make sure your working in the shade if its hot, and work with smaller pieces, as it makes it easier to handle and apply.....
Old Aug 1, 2001 | 09:26 PM
99niner99's Avatar
Well said...take your time and do it right or else when it starts to peel and come off later...you'll be sorry you didn't do it right the first time.
Old Aug 2, 2001 | 10:38 AM
riggy's Avatar
does anyone have a link to where i can find directions??
Old Aug 2, 2001 | 12:04 PM
khrfadz's Avatar
cool thanks alot for the help
Old Aug 6, 2001 | 05:19 PM
StaindMaxima's Avatar
Dynamat
Dynamat makes a kit specifically designed for the trunk of a car with a special type of Dynamat for the trunk lid, quarter panels and remaining surface area. If you can get your hands on one of those kits you wil be in great shape. I have seen them at Circuit City and other smaller shops. Most places that carry Dynamat can order the trunk kit even if they don't have it in stock.
The Dynamat should be applied to a clean surface. The best way to apply it is to set it down where you want it and use a heat gun to mold it to the car's contours, making sure that there are no bubbles. The heat gun is vital in my opinion. It makes the Dynamat stick 100 times better that just pressing it to the car with a roller tool.
Old Aug 6, 2001 | 10:30 PM
khrfadz's Avatar
Re: Dynamat
thanks for the info
Old Aug 7, 2001 | 08:13 PM
DARTHSWAN's Avatar
Re: Dynamat
See if you can find someone who works at Circuit City, it cost about 55 dollars. A lot cheaper than the 129 or so. Trust me it is worth it. I had to turn my amp gains down after using it.
K
Old Aug 7, 2001 | 09:03 PM
RideTheMax's Avatar
Cost...
does anyone know how much (about how much) it would cost to buy dynamat and have it installed by someone else at a sound shop? will they even do it? I really don't have the time or know how, and I especially don't have the patience. Thanks for your help.
Old Aug 8, 2001 | 05:43 AM
Whitemax's Avatar
Disco Biscuit
ALOT. Figure its around $50 an hour to get a local shop to do anything, and figure 2 to 3 hours( on the low side) to do the installs, plus the fortune they charge for Dynamat, you're looking at some change. forum.elitecaraudio.com has a guy on there named rick that is selling a sound treatment stuff on there he calls RAAMmat for $55 for a 50 sq. ft roll. That is an insainly low price for sound treatment. It's very plyable,(unlike dynamat), VERY sticky,(unlike dynamat), and has an aluminum face to it. I used it to do my car, and it was the easiest stuff to work with I've ever used, becuase you dont need a heat gun.
http://forum.elitecaraudio.com/showt...threadid=26341
Old Aug 8, 2001 | 06:57 AM
delio's Avatar
How many rolls do you think you need for a Max?
Del
Old Aug 8, 2001 | 06:37 PM
Dynamat
A trunk kit install at Circuit City is $62, plus the kit, at least in my area, the northeast. I am in Mass, I will do it much cheaper.
Ryan
Old Aug 8, 2001 | 07:37 PM
Whitemax's Avatar
Disco Biscuit
Del
It realy depends on how much you want to do. The trunk, front doors, rear deck, all the pillars and the center console are what I've found rattle the most. I used close to 100 sq. ft, and it's stopped just about all of it.
Old Aug 8, 2001 | 11:17 PM
khrfadz's Avatar
is there anything else that i can use but dynamat?? its pretty expenisve and i want to know if there is another cheaper method
Old Aug 9, 2001 | 11:33 AM
riggy's Avatar
Re: Dynamat
Ryan
i go to school in amherst, where are you and how much would you charge to do it??
Old Aug 9, 2001 | 03:06 PM
Whitemax's Avatar
Disco Biscuit
See my above post about RAAMmat.
Old Aug 9, 2001 | 04:11 PM
Re: Re: Dynamat
I am 10 mins from Providence in SE Mass. $50 and I will install it for you. Lemme know ahead of time and I can probably get the trunk kit really cheap for you too.
Ryan
MECP Certified Installer
Old Aug 11, 2001 | 08:33 PM
SWEETSOUND2001's Avatar
I'm currently in process of using raam mat to do the inner part of all my doors. After that I will finish the rear deck, headliner (pray for me) pillars, and my wheel wells. I want to get some ideas from you guys on what should I do about the wheel wells to cut down on road noise.
And here is the link to my website with over 100 sound deadening pics and tons of info on my maxima.
http://maxima.cardomain.com/id/sweetsound2001
Anton
Old Aug 12, 2001 | 06:35 AM
Whitemax's Avatar
Disco Biscuit
Anton, you're a brave soul to tackle the headliner. Isnt there foam in there already from the factory though?
Old Aug 13, 2001 | 12:19 AM
There may be some foam but I will apply damping sheets (2 layers) and glue some carpet padding as well. Will see how it goes. I just put in two layers of raam mat in my rear doors. I love the way they sound when I slam them shut. It's just a thud, without any resonance.
Old Aug 13, 2001 | 07:45 AM
Toolrocks's Avatar
What part of the wheelwell are you concerned with. Can you just spray a ton of undercoating on it? I think Rockford or somebody makes a Dynamat type substance that gets sprayed on if undercoating wont do the trick.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
