What do you guys think of FI subs?
Old Dec 8, 2007 | 08:30 PM
  #41
filtor1's Avatar
Originally Posted by Jess
Solid Audio F11D they don't make em anymore I don't think.
It hits harder now after I actually set the amp instead of using the HU to set the bass.
Awesome. Haven't ever used their amps but have never heard of any major issues with them. Did you ever post pics of the finished box?
Old Dec 9, 2007 | 12:27 PM
  #42
Jess's Avatar
SHIFT_In2D
I don't believe I did, but I have a video there. Temporary box until I can get a fiberglass one done. I'm trying for one that takes up the least amount of space possible. I don't think I can switch to a 12 even though it's smaller. I'd really miss the super low notes
Old Dec 9, 2007 | 11:18 PM
  #43
joebangaa's Avatar
Originally Posted by The Law
I have almost no exterior rattle with my system
With my system turned up, you wouldn't have known that I have a system unless my windows were rolled down.
Weakness...
Doesn't matter how much deadening you got.. on an A33, it WILL rattle with enough deebeez.
I've got a video floating around of my trunklid and rear windshield ready to bust out from "just" two TC9 driven 12"s...
Old Dec 10, 2007 | 04:12 PM
  #44
01GLEMist's Avatar
Up front;
Pioneer 880PRS
Kicker ZX850.4
Rainbow Powerline CS's (only have fronts)
Out back;
SS PCA2000D (still waiting for my D61500.1, been 6months)
2-Fi Q 12's (no options)
3.9 cf after port and sub displacement (largest that fit)
Slot port, tuned to 32Hz
Dedicated YellowTop in the trunk
Big 3 and all other power wire is 0gauge
240+sqft of Stinger Extreme Roadkil
I am looking for someone with a camera so I can get some good video.
do you or someone else have the max dimensions of an enclosure that will fit through the trunk opening of a 2000-2003 Maxima? I am planning on building my first box ~2.5 cubes, but i have no idea on the max width and other dimensions
Old Dec 11, 2007 | 10:45 PM
  #45
joebangaa's Avatar
2.5 ft^3 net? Sealed or ported? What's the driver displacement?
Generally, 2.5 ft^3 should have no problem fitting in our trunks, even if it's vented. I used to run a 3.5 ft^3 ported box. Don't have the dimensions off hand...
Your maximum width will probably be the distance between the wheel wells in the trunk right behind the rear seat....unless you plan on having some funky design.
Old Dec 11, 2007 | 11:10 PM
  #46
filtor1's Avatar
I will get you the measurement, brb.
OK, Width=39", Hight=16", Depth=15". These are safe measurements and will fit. It won't drop right in though, you will have to slide one side in all the way to one side of the trunk to get the other side in.
Old Dec 11, 2007 | 11:11 PM
  #47
filtor1's Avatar
The curvature of the trunk opening prohibits the width as do the trunk arms and tension bars.
Old Dec 12, 2007 | 12:24 AM
  #48
The Law's Avatar
I R The Law
Weakness...
I have no deadening except my license plate frame and I have barely no exterior rattle.
Old Dec 12, 2007 | 05:32 AM
  #49
01GLEMist's Avatar
yea exactly, thats why i knew i couldnt just go and measure the inside space
but the box 2.3-2.5cubes net after all displacements including .16 cubes for a 12" Fi Q, and tuned to 32Hz.
and filtor1, thanks a lot for the measurement, it sounds similar to what i measured a while back, but i was uncertain
Old Dec 12, 2007 | 10:57 AM
  #50
JEXTEL's Avatar
FI subs rock...lol
Old Dec 12, 2007 | 01:57 PM
  #51
filtor1's Avatar
No problem. I didn't read that you were using a single 12". You will be fine with just about anything with 2.5 cf. BTW, you will love it tuned to 32. If you listen to more rock try 35 instead. You will have a much easier time blending with the front stage.
Old Dec 12, 2007 | 01:58 PM
  #52
filtor1's Avatar
Originally Posted by JEXTEL
FI subs rock...lol
What are your hybrids?
Old Dec 19, 2007 | 07:49 PM
  #53
JEXTEL's Avatar
concept and FI(FI soft parts and added cooling) only took 110 for a 1000wrms gain in power...
Old Dec 19, 2007 | 10:24 PM
  #54
filtor1's Avatar
Awesome!
Old Jan 7, 2008 | 06:40 PM
  #55
01GLEMist's Avatar
Pete, from www.hexibase.com is designing an enclosure for me. He wants to do:
Depth=18"
Width=39"
Height=16"
you guys think this would fit inside the trunk opening and actually fit well?
Old Jan 7, 2008 | 08:41 PM
  #56
020189's Avatar
NY State Of Mind
Heard nothing but good things about them.
Old Jan 8, 2008 | 03:50 PM
  #57
01GLEMist's Avatar
Depth=18"
Width=39"
Height=16"
bump^, would this enclosure fit into the opening of a 2001 maxima's trunk with no problems?
Old Jan 8, 2008 | 03:53 PM
  #58
AscendantMax's Avatar
39" is pretty wide. i had issues fitting a 35 into my old 3rd gen. i can't imagine the 5th gen's opening being that much bigger.
Old Jan 8, 2008 | 09:21 PM
  #59
filtor1's Avatar
Depth=18"
Width=39"
Height=16"
That is a pretty big box. I would cut the depth down a bit, but the width will fit. Not easily, but it will.
Old Jan 9, 2008 | 05:04 AM
  #60
01GLEMist's Avatar
thanks,
its a horn for a hdc3 12"
Old Jan 9, 2008 | 01:30 PM
  #61
filtor1's Avatar
thanks,
That should be awesome!
Old Jan 10, 2008 | 05:54 AM
  #62
lombardozzi's Avatar
Fis are one of the nicest subs out there. Compare to RE....
Old Jan 10, 2008 | 09:08 AM
  #63
Dracc's Avatar
i have 2 Fi audio BL's 12's ..... cost about a grand after shipping
Old Jan 10, 2008 | 10:07 AM
  #64
JEXTEL's Avatar
Depth=18"
Width=39"
Height=16"
the only way i see that fitting in your trunk if you side it in long ways then turn it back around while its in your trunk but even then you can only keep the box very close to the hatch..good for spl bad for a daily driver(well if you dont mind not using your trunk..)
you got ripped because there less then $600 shipped for 2!
Old Jan 10, 2008 | 10:09 AM
  #65
JEXTEL's Avatar
thanks,
let me know about that hdc3 i want 6 15's on 3 opti2000d's for my blazer..i have heard nothing but good things about them expect for you need a larger then normal box to get loud...
Old Jan 10, 2008 | 10:15 AM
  #66
BLACKonBLACK98's Avatar
Former Vendor
little more if you add in all the options, but yeah...
Old Jan 10, 2008 | 10:20 AM
  #67
JEXTEL's Avatar
i understand that but you can add all the option and still be a the $800 mark..and FI has free shipping...
Old Jan 10, 2008 | 10:34 AM
  #68
Former Vendor
thats what i was saying. but seeing as you can only buy fi from fi (afaik) i'm sure theres either some special circumstances or mild exaggeration going on.
Old Jan 10, 2008 | 01:01 PM
  #69
JEXTEL's Avatar
ooo tru then...
Old Jan 10, 2008 | 01:16 PM
  #70
filtor1's Avatar
Did you order direct? That is way too high.
Old Jan 10, 2008 | 01:21 PM
  #71
filtor1's Avatar
Ummm no. I have seen boxes close to the hatch lower and raise spl as well as sound "better" and "worse" under the same scenario. This is driver, box, and vehicle dependent.
Starrider
Dec 18, 2015 04:43 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
nbstriker10
Sep 4, 2015 04:26 PM
