The BOSE Radio/Speaker Replacement thread
Old Jan 10, 2011 | 02:06 PM
  #601
Froggmann's Avatar
Gotta go do a job but here's some self help: http://www.nicoclub.com/FSM/G20/2002_G20/2002_G20/
The electrical section is EL.pdf
The one that shows you your fuse boxes is the foldout.
Old Jan 10, 2011 | 02:41 PM
  #602
techiedork's Avatar
WOO HOO!!!! I figured it out!!!!!
I tested everything with the multimeter - fuses are good, wire run from fusebox to HU connector is good, so I was stumped!
Then I looked at the Metra wiring diagram and realized that the illumination wire (orange) and acc power (red) are right next to each other. So, I turned on the headlights again and tested the red wire and got 12 volts! After looking closer at the diagram, I realized that Metra reversed the 2 wires! The orange is where the red should be a vice versa!!!!
So, I connected the harness with the current wiring and figured that if I turn on the headlights (which would supply the 12v to the acc) it should work.....and viola! It works!
So all this time, it was as simple as Metra reversing the 2 wire colors!!! ARGH!!!!
I will call them and find out why that happened, but all I have to do now is re-solder and everything should be done!
Thank you all so much for the help! I really appreciate it!!!
-David
Old Jan 10, 2011 | 06:58 PM
  #603
djfrestyl's Avatar
Suspension Yoda
Well done
Old Jan 10, 2011 | 09:44 PM
  #604
Froggmann's Avatar
-David
You must have had the same guy I had put your harness together. My RCA connectors were completely backwards. Left Front was colored for right rear, left rear was right front and so on. Glad you got it figured out.
Old Jan 10, 2011 | 10:08 PM
  #605
Joeker82's Avatar
Dude, check to make sure you don't have the remote and antenna lead hook up backwards.
Old Jan 11, 2011 | 12:33 PM
  #606
techiedork's Avatar
OK, so everything is now installed and seems to be working properly. The only thing I do notice is that the volume is a little on the low side, and cranking it up to a bit louder causes some distortion.
Would I be better off using the Scoche OEA-4 instead of the Metra 70-7551 harness?
Thank you!
-David
Old Jan 11, 2011 | 01:03 PM
  #607
djfrestyl's Avatar
Suspension Yoda
Thank you!
-David
Yes, sounds like you need an LOC.
What kind of HU do you have installed? This is precisely the reason why the preout voltage of your HU determines which installation avenue you should go with - 70-7551 or LOC.
Old Jan 11, 2011 | 01:10 PM
  #608
techiedork's Avatar
Hey djfrestyl - yeah, I was doing reading on both and settled on the metra harness, but think I may need to go with something else - I am using a JVC HU with 2.5v preouts.
Given the low voltage, should I switch over to LOC? If so, is the Scoche OEA-4 a good choice, or do I need to go with the PAC ROEM?
Thank you!!
Old Jan 11, 2011 | 01:18 PM
  #609
djfrestyl's Avatar
Suspension Yoda
2.5v is definitely too low. Either LOC is fine, they both work well.
Old Jan 11, 2011 | 02:39 PM
  #610
techiedork's Avatar
Yeah, that is what I was thinking...do you have a preference between the Scoche or PAC in terms of ease of installation or ease of fine-tuning?
Old Jan 11, 2011 | 02:58 PM
  #611
djfrestyl's Avatar
Suspension Yoda
Nope not really. Installation is the same, a bunch of wires
Go for the one that's cheaper?
Old Jan 11, 2011 | 03:12 PM
  #612
techiedork's Avatar
Will do....
is the fine tuning a pain, or is it relatively easy?
thank you so much for the help!
Old Jan 11, 2011 | 03:25 PM
  #613
djfrestyl's Avatar
Suspension Yoda
Crank your radio to about 90% with the adjuster ***** on the LOC at 0.
Then slowly increase each **** till you hear distortion, then back off a little.
Old Feb 11, 2011 | 07:08 PM
  #614
S3AN GOTTI's Avatar
Noob in this particular forum.
Just picked up an 07 Maxima SE.
Swapping in the following HU to a non nav bose setup. (Alpine IDA-X305 w/ PXA-H110 Kit)
If I've read everything correctly. I'll need the Metra 70-7551 wiring harness. (4v pre-outs on HU w/ PXAh100 kit) and the Metra antenna adapter. To hook to the factory bose speakers/amps.
**ACTUAL QUESTION BELOW**
My vehicle has steering controls and factory bluetooth. I want to retain both and I am unfamiliar with the factory wiring.
Thus far I have located the following products to retain each feature individualy. But can they work together/wire up without issue?
Steering wheel adapter: METRA ASWC
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
Bluetooth adapter and trip information: AXXESS NIRD-01 (Buggy but works)
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Any input in greatly appreciated.
Thanks!
Old Feb 13, 2011 | 08:31 PM
  #615
HomerMAC's Avatar
Donating i30 Owner
THANKS TO THE OP for the METRA :Metra Part 70-7551
harness model number... i spend three months trying to figure out which harness that is. I saw it a long time ago and couldnt remember who made it. IT is perfect. I hate that soche converter which kills quality. THANK YOU!!!
Old Feb 14, 2011 | 05:49 AM
  #616
djfrestyl's Avatar
Suspension Yoda
Old Feb 20, 2011 | 03:35 AM
  #617
illmannered_1's Avatar
First Post! I apologize for not reading the entire thread, I've spent countless hours searching for the answer to my question to no avail. I tried the install months ago and didn't get it right, due to the fact I had never read this thread now im tired of the radio and want to give it another go. I bought the dash kit and the basic scosche wiring kit (not for bose).
My question is as follows:
Can i splice rca connectors to my basic wiring harness to effectively make my own Metra style harness? Has anybody done this, or should i not open it, return it and order the Metra?
Old Feb 20, 2011 | 04:08 PM
  #618
djfrestyl's Avatar
Suspension Yoda
YES, you can splice RCA's right in!
Old Feb 27, 2011 | 09:14 AM
  #619
HomerMAC's Avatar
Donating i30 Owner
lol.. once i recieved mine.. i was a litle pissed as I thought there was a resistor or something in there... then realized it is just RCA..... but i guess for 12$ shipped i couldnt complain that much.
Old Feb 28, 2011 | 12:45 AM
  #620
maxx0831's Avatar
when using the amp integration Harness for the bose 2002 max, which input do you plug the green, gray, purple and white rca. I know you plug it in the back but in the back are red and white inputs
Old Feb 28, 2011 | 06:21 AM
  #621
djfrestyl's Avatar
Suspension Yoda
On your HU,
Red = right
White = left
Then they should be labeled as front/rear
On the harness,
Purple & Green = rear
White & Gray = front
Old Feb 28, 2011 | 10:35 AM
  #622
maxx0831's Avatar
On your HU,
Red = right
White = left
On the harness,
thank you bro, for the purple and green, Which is right and which is left or it doesnt matter?
Old Feb 28, 2011 | 07:56 PM
  #623
djfrestyl's Avatar
Suspension Yoda
It definitely matters - check the package of the harness, I can't remember off the top of my head.
Old Mar 1, 2011 | 11:12 AM
  #624
maxx0831's Avatar
thanks bro, I got it.. Its on the package just like you said
Old Mar 1, 2011 | 04:28 PM
  #625
S3AN GOTTI's Avatar
Anyone have any input on this?
Old Mar 17, 2011 | 01:34 PM
  #626
Lsgun1's Avatar
Hey guys I just installed an Alpine IXA-W407 with a PAC OEM NIS2 and everything works EXCEPT for the subwoofer won't turn on, I've double checked all my wiring is correct...ideas?
Old Mar 26, 2011 | 12:25 AM
  #627
T.One's Avatar
ok went through 2 pages. too lazy to read the rest. How can I rewire the factory bose wires to bypass the bose amps and use an external amp on new aftermarket speakers? I would rather use the stock ****ty 20ga or whatever wires and power my cheap pioneers with an external amp.
Old Mar 26, 2011 | 05:30 AM
  #628
djfrestyl's Avatar
Suspension Yoda
The info is in this thread. Read it
Old Apr 4, 2011 | 11:50 AM
  #629
nissangrrl's Avatar
a question for you electronics people
so i had to put an aftermarket radio in my 99 maxima that has the bose system in it...actually have a couple questions...
first...when listening to my mp3s ...especially those with heavy bass ...im getting static not tons of distortion ...just alot of static ...what fixes that
also...i have a ground loop...not a big deal...however...can that ground loop cause a spike that would make my bat and brake lights come on...already had the alternator and battery checked by 4 different places...all are saying good and seem to be charging fine...so im wondering if it was just a spike?
thanks for the help
Old Apr 4, 2011 | 12:07 PM
  #630
djfrestyl's Avatar
Suspension Yoda
Need more info. How do you have your radio connected? Via an LOC? PAC adapter?
What makes you think you have a ground loop?
Old Apr 8, 2011 | 12:47 PM
  #631
maxima1213's Avatar
Old Apr 13, 2011 | 11:52 AM
  #632
nissangrrl's Avatar
im almost positive the static is because my guy just hooked it up to the generic walmart wiring harness<i live in the middle of nowhere...its all we have> and nothing else...now that ive read thru this forum more...
i know i have a ground loop cause i can hear it
appreciate the help
Old Apr 14, 2011 | 05:23 PM
  #633
kukx30de's Avatar
Is there a way I can use the bose sub but use an aftermarket amp too?
I hv a pioneer 4300 and wanted to add a set of budget components in the front and coaxials in the rear doors.
I will be using an alpine MRF-240 amp which puts out 50X4.
Old Apr 14, 2011 | 05:53 PM
  #634
djfrestyl's Avatar
Suspension Yoda
Yes, just splice some female RCA's to the speaker leads coming out of the Bose HU. Those are your preamp signal wires for your 4 channel amp. Replace the 4 Bose speakers with aftermarket, done.
Old Apr 14, 2011 | 06:30 PM
  #635
kukx30de's Avatar
I already hv an aftermarket HU and right now I'm using the metra 7551.
Still same thing?
Old Apr 14, 2011 | 06:59 PM
  #636
djfrestyl's Avatar
Suspension Yoda
Hmm...
To keep your Bose sub working, you will have to continue to use the 70-7551. But you have to use the front/rear RCA preouts or the new amp.
So - either get splitters for the RCA's, or yea, splice a pair of female RCA's on there.
Old Apr 15, 2011 | 10:24 AM
  #637
kukx30de's Avatar
Another thing I am noticing is with the current state:
Pioneer AVH 4300DVD with Metra 7551
Stock Bose speakers and amp
I am not super happy with the sub... level feels kind of low. Since I have used rear/front preout with the metra, the sub controls are not working.
Is there a way around this?
Basically looking to see if I can control the sub.
Worse case, I will add the alpine with a set of polk DB6500 i hv in the garage and some cheap ones for the rear doors. that way I can hv the HU sub line going directly to the bose sub.
Old Apr 17, 2011 | 06:44 AM
  #638
djfrestyl's Avatar
Suspension Yoda
The sub signals do go through the preouts. Which one, im not sure of.
Try this. At the sub amp, figure out which wire is the preout signal. Then run an RCA from your sub output on your HU to those two wires. Cut the wire though, so that the 2 signals don't mix/cross.
Old Apr 28, 2011 | 10:54 PM
  #639
healingduck's Avatar
Is is it true that this will work in my 4th gen instead of the metra 70-7551? By the way, I am using the stock amp and Bose speakers. Just replacing the HU.
http://www.crutchfield.com/p_142C4NN...w&rvm=ShowAllt
Old Apr 29, 2011 | 06:02 AM
  #640
djfrestyl's Avatar
Suspension Yoda
^^ Yes, that will work as well.
