The BOSE Radio/Speaker Replacement thread
Old Aug 22, 2009 | 07:36 AM
  #321
djfrestyl's Avatar
Suspension Yoda
Why did you buy it, then ask if it were possible to bypass it?
Is the HU turning on? Are you sure the remote turn on is hooked up correctly?
Old Aug 22, 2009 | 09:01 AM
  #322
twostepbehind's Avatar
The HU turns on, finds radio stations, plays CDs as well as my iPod but nothing is making it to the speakers. I bought it because I didn't really know what I needed and when I posted and asked I got no response. I'll take pictures when I get home this evening, maybe there's a flaw in my wiring.
Old Aug 22, 2009 | 09:14 AM
  #323
djfrestyl's Avatar
Suspension Yoda
Possibly wiring. All the information is in the stickies though, which is likely why no one responded.
Old Aug 22, 2009 | 02:37 PM
  #324
Well I took some pictures and looked at both the harness book and the HU book and everything seems to be connected right. I seem to be having the same problem that laub did earlier on in the thread. I have aim and msn so if anyone wants go contact me there go ahead.
Here are some pictures.
http://tinypic.com/r/9jhe6r/3
http://tinypic.com/r/21j6idf/3
Here's the black, blue and orange that I don't know what to do with. I'm assuming I need to ground the black wire.
http://tinypic.com/r/2j7iuq/3
Here's the black/white and a blue/white that I don't know what to do with.
http://tinypic.com/r/vnf1g2/3
http://tinypic.com/r/ftq4n7/3
I don't believe I need to use any of these wires, do I?
Old Aug 22, 2009 | 06:46 PM
  #325
All is good, my HU is installed and sounds great. Nismos was kind enough to help me out and point out what I needed to do.
You have to ground a wire behind the head unit. I'm 95% sure it's the brown wire with yellow stripe in the small white harness (the harness only has about 3 wires in it)
Looking for a confirmation on this now
Old Aug 22, 2009 | 11:14 PM
  #326
djfrestyl's Avatar
Suspension Yoda
The above post is correct.
Old Aug 25, 2009 | 08:27 AM
  #327
Revo75's Avatar
thank you so much for this you have no idea how much it's helped!
Old Aug 25, 2009 | 10:28 AM
  #328
djfrestyl's Avatar
Suspension Yoda
Good, glad to hear it!
Old Aug 25, 2009 | 02:18 PM
  #329
seans90maxima's Avatar
EDIT- If you guys have a whine with BOSE, its the amps, that was my problem, very simple to bypass. A 16 yr old can do it.
On the third gen.
Unplug the WHOLE Speaker, then cut off the plug that is in the door..
Tape off/cover up the two big wires.
Then for the small two.
Drill a hole in the speaker housing.
Pushed the wires through.
Connect these two smaller ones to the speaker wires.
White/whatever is positive. Black/whatever is negative.
Worked for me, no whines.
Old Sep 10, 2009 | 03:12 PM
  #330
Revo75's Avatar
why is this not stickied!?!?!?!!?!111!!?!?!1
this has been a HUGE HELP! sucks i have to search for it any time i need it
Old Sep 10, 2009 | 08:59 PM
  #331
djfrestyl's Avatar
Suspension Yoda
Glad it helped. If you need assistance, there are plenty of knowledgeable people in the area (myself included) that can help you out.
Old Sep 11, 2009 | 10:32 AM
  #332
maxima_boi's Avatar
Sorry if this has been asked. I have an 01 maxima with Bose and I can't figure out the wiring for my aftermarket stereo. I have looked at diagrams but none are clear enough. Can anyone post the colors/what they are for? Like yellow/battery
Old Sep 11, 2009 | 10:34 AM
  #333
djfrestyl's Avatar
Suspension Yoda
It has been posted - read the stickies. You shouldn't need the wire colors. Just get the right harness and match the colors. For an aftermarket radio to Bose system, you need Metra 70-7551.
Old Sep 11, 2009 | 11:03 AM
  #334
maxima_boi's Avatar
Well I was trying to wire it in without buying a wire harness or adapter. Is that possible?
Old Sep 11, 2009 | 11:27 AM
  #335
djfrestyl's Avatar
Suspension Yoda
It's possible, but extremely stupid, especially for someone who does not know what they are doing. You absolutely need an antenna adapter harness, and I VERY strongly suggest you just use the Metra harness aforementioned as well. The hassle and potential problems you could cause are not worth the $9 you'd be saving.
Old Sep 11, 2009 | 12:22 PM
  #336
maxima_boi's Avatar
Well Is there any way someone could tell me how to wire it without the harness. Will I need the antenna adapter even if I dnt want the radio?
Old Sep 11, 2009 | 12:24 PM
  #337
djfrestyl's Avatar
Suspension Yoda
The information is out there somewhere, but I'm definitely not going to search for it for you.
No, if you don't want the radio, then I suppose you don't need the antenna adapter.
Old Sep 11, 2009 | 12:32 PM
  #338
maxima_boi's Avatar
Ok well thanks for your help! I been looking for the info but all I can find is diagrams of the wires inside the plastic housing not the wire colors. If anyone can find a color diagram I would appreciate it.
Old Sep 11, 2009 | 12:42 PM
  #339
djfrestyl's Avatar
Suspension Yoda
I don't know why I keep trying with you, but for the last time - It's not worth it. Just get a harness.
You're also going to have to splice in RCA's to maintain usage of the Bose system.
Old Sep 11, 2009 | 01:50 PM
  #340
maxima_boi's Avatar
Ok well for one I'm trying to do this without buying more parts. I already clipped off the other ends of the wires. Well my friend did. Plus I'm not going to use the crappy Bose system I have my own subs and amp. I just need help getting my cd player installed I can do the rest.
Old Sep 11, 2009 | 03:18 PM
  #341
djfrestyl's Avatar
Suspension Yoda
Have your idiot friend purchase a reverse harness and fix it, then use the proper harness.
Old Sep 11, 2009 | 03:20 PM
  #342
djfrestyl's Avatar
Suspension Yoda
Here's a freebie:
Reverse harness:
http://www.ioffer.com/i/Nissan-MAXIM...Wire-115191435
Old Sep 26, 2009 | 10:08 AM
  #343
dukelubas's Avatar
Org Lurker
I hate to bring up an issue that's been discussed already (and I've read ALL the posts and searched extensively), but I want to get this right before I lift a screw driver.
I've got a new Pioneer HU and a brand new Metra 70-7551. Trying to replace my Bose HU in my 4th gen (97).
1) From my understanding both ground wires on the Metra and the ground from the HU harness all go to chassis ground, correct?
2) Pioneer's blue/white "System Remote Control" wire turns on the Bose amps so that wires to the blue/white on the Metra correct?
3) Metra's blue wire for Power Antenna - goes to what? Does it get wired into the same Pioneer blue/white remote wire? From searching, it seems there are issues with the antenna going up every time the HU is powered up regardless of source.
4) I have not gotten the Antenna adapter yet, but I guess I need to in order to get a decent radio signal right?
5) This Pioneer has DVD capabilities and has a purple/white wire that needs to get wired into the "Reverse-Gear Signal Input". I haven't searched for this wire yet - can somebody speed this up and tell me where I can find it within my 4th gen?
6) The Pioneer also has a green parking brake wire which I'm assuming I can find easily at the parking brake. I'm assuming the parking brake has a black (or black stripe) for ground so use the other wire for positive.
I've installed radios before and I want to get all my ducks in a row before I even start so I'm not constantly running in and out of my car doing searches for problems online. Thanks for any help.
Old Oct 5, 2009 | 04:16 PM
  #344
kurtibm's Avatar
Hi,
I'm looking for a reputable place to have my (6th gen - 2005)Bose 6- disc cd changer repaired. Optimally I'd like to find a place that might sell one on 'exchange' so that I can do the R&R job all-at-once. Otherwise, just a reputable, fairly-priced repair shop would be great...
Thanks for any and all help...
Kurt
Old Oct 5, 2009 | 05:46 PM
  #345
djfrestyl's Avatar
Suspension Yoda
Just replace it with aftermarket.
Old Oct 8, 2009 | 05:57 PM
  #346
silent818's Avatar
I got a question. I recently replaced my Bose HU with a 7" Touchscreen DVD/GPS... HU using the 70-7550 Harness (because my previous Maxima didn't have a Bose system. so I was unaware of this issue) anyways. I just ordered the METRA 70-7551 so my question is Where do those 4 RCAs go ?
11-18 RCA Output? (11,12,17,18?)
Old Oct 8, 2009 | 06:13 PM
  #347
djfrestyl's Avatar
Suspension Yoda
Yes, RCA preout of your HU. The numbers you posted are correct.
Old Oct 8, 2009 | 07:12 PM
  #348
ButtaMax's Avatar
I cant wait to dump the whole Bose system!
Old Oct 8, 2009 | 08:13 PM
  #349
silent818's Avatar
thanks for the fast reply
so wires 5,6,7,8 must be ignored right?
because i was thinking maybe I could use those to put 2 aftermarket speakes in
Old Oct 8, 2009 | 08:19 PM
  #350
djfrestyl's Avatar
Suspension Yoda
Yes, ignore them.
You could, but why?
Old Oct 9, 2009 | 03:53 AM
  #351
silent818's Avatar
why not
There was a thread about it here somewhere about putting speakers on the rear doors (like most newer model cars)
but that seems like too much work for me.
Old Oct 9, 2009 | 04:50 AM
  #352
djfrestyl's Avatar
Suspension Yoda
You could throw some speakers in the doors, totally your call. It's not actually all that hard.
Old Oct 13, 2009 | 06:27 PM
  #353
simo711's Avatar
Swap out 94 HU with a 95 HU
My 94 HU just died...I noticed quite a few 95 HU's on eBay and want to know if I can swap a 95 for my dead one. They look the same but I know that looks can be deceiving in stereo land!
Thanks for the help and advice.
Old Oct 13, 2009 | 07:20 PM
  #354
djfrestyl's Avatar
Suspension Yoda
I have a feeling they'll fit.
Old Oct 31, 2009 | 06:04 PM
  #355
icemanf14d's Avatar
Sunlit Sand Beauty
im changing the HU on my 03 GLE.
I currently have the stock Bose set up. I want to get the Kenwood KDC-x493.
ive been reading alot the last couple of days but just to clarify, i need the Metra 7551 wiring harness separate to the antenna and dash kit supplied by Crutchfield ( im getting the HU from them and taking everything to a place near my house, charges $50 for installation)
is that all i need to make the amp and sub work?
Old Oct 31, 2009 | 09:07 PM
  #356
djfrestyl's Avatar
Suspension Yoda
Correct: Metra 70-7551, antenna adapter, dash kit.
Old Nov 5, 2009 | 08:16 PM
  #357
popai21's Avatar
The system replacment
Sorry for the Noob question. I am just not familiar with anything concerning the electronic is the Infiniti i30 1996 car that i recently bought.
I really want to replace the CD/RADIO system with a nice Sony Or Pioneer one.
Can some one please help me and guide me what can i buy. What do i need to look for in the New system. Would It harm the speakers. Would it work perfectly with the surround system in the car? Is there anything special i need to know regarding the installation (any frequency changes?)
Old Nov 6, 2009 | 04:49 AM
  #358
djfrestyl's Avatar
Suspension Yoda
First, welcome to the forum!
Second, this basic knowledge has been discussed ad-nauseum.
Please start by reading the stickies and you'll find the information you're looking for.
Old Nov 6, 2009 | 05:26 AM
  #359
Rhyno02's Avatar
I know all the specifics were covered to replace the Bose HU but, I was just curious if it makes a difference with installation if you have the factory nav, thanks. I would like a new hu and to put my subs in that I have lying around but if it's too much of a PITA, I'll just sell the subs...
Old Nov 6, 2009 | 05:57 AM
  #360
djfrestyl's Avatar
Suspension Yoda
Factory NAV is completely different. It interfaces with the HVAC. You're better off keeping the factory NAV and just adding subs.
