Alarm install help....
Old Mar 17, 2008 | 08:49 PM
aznstormin's Avatar
Ok, I know most everyone says to not install it myself, but I DID. And Idid it correctly... almost.
This is just a cheap aftermarket alarm. I wired everything I needed, except the DOOR TRIGGER wire. I know it's located in the "low driver's kick" from the wiring diagram, but I can't find it.
Where is the "low drivers kick" located? ... I've looked all over for it and can't find the door trigger wire.
Old Mar 18, 2008 | 06:36 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Guessing its a 4th gen?
Kickpanel is the small panel down to the bottom left of your ankle. Remove that then uncover the large black platic loom cover ton of wires. Door trigger is Red/White stripe. How did you locate trunk trigger and truck release without accessing that area?
Old Mar 18, 2008 | 07:15 AM
aznstormin's Avatar
Yeah, sorry, it is a 4th gen; 98 to be exact.
Heh, and I didn't connect the trunk wires because I don't have a power trunk (it's the manual handle, so I don't really want to mess with that).
Is the loom of wires behind the fuse box? Because I thought that it was that panel right next to the dead pedal (automatic), but there were practically no wires there. All the wires were up behind the fuse box. Just wasn't sure if I were to disconnect it from the large connector thing.
Old Mar 18, 2008 | 07:27 AM
Pearl96Max's Avatar
You would still have a trunk trigger.
Its a large loom (vinyl) behind the kick. You may have to pull back an inch or so of carpet to make it visible.
Old Mar 18, 2008 | 11:03 AM
aznstormin's Avatar
Hmm thanks. I'll take a look again tomorrow.
Old Mar 21, 2008 | 04:13 PM
aznstormin's Avatar
Thanks, I got it done... I was hoping that loom of wires that I didn't have to take apart xP. Oh well, thanks.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
