Need more headroom
Old Apr 1, 2008 | 08:28 AM
ElVito1981's Avatar
Need more headroom
Hey guys.....I've been running an Audison LRx 2.9 for almost a year. It puts out 260 watts RMS per channel--using it to power my DLS 6.5" Iridium 3-ways. I'd like to have more headroom. Anyone know of a high-power used 2-channel amp for sale? Thanks.
Old Apr 1, 2008 | 03:10 PM
mendon99's Avatar
tastey wheat
260 watts a side and you want more?
Old Apr 1, 2008 | 03:12 PM
ElVito1981's Avatar
if possible yeah. Cause to get my system to play where I want it, I have to crank my Eclipse to between 60-65 volume level (out of 80). I want to only have to crank it up to between 35-40. Since the Eclipse is 8V preout, I only have the gain on the amp at 50%
Old Apr 1, 2008 | 03:48 PM
nismos14's Avatar
§è~® f®ÈÄk
Why? Your headunit isn't clipping at that volume (for reference my eclipse had to be turned up beyond 70 to get loud when I had it). The gains are probably set somewhat low on the amp too.
Old Apr 1, 2008 | 03:50 PM
AscendantMax's Avatar
260 per side is quite a bit. i don't even have that much power going to my germaniums. granted my amp can do 320 x 2...but even so i "only" have it tuned to about 200 watts to each side. it gets damn loud at volume 50 on my CD5100. i usually listen to between 30-40.
Old Apr 1, 2008 | 04:08 PM
kpr10is's Avatar
SSLD6?
Old Apr 1, 2008 | 04:55 PM
mendon99's Avatar
tastey wheat
I have 150w per side on mine, gains ~45%, and it gets decent loud. Maybe you should invest in some deadning?
Old Apr 1, 2008 | 05:10 PM
travmaximas1998's Avatar
+1 for deadening
Old Apr 1, 2008 | 05:12 PM
mendon99's Avatar
tastey wheat
actually now that i think of it a single volume step on an Alpine is like 10 on an Eclipse, so what you're experiencing is probably normal.
Old Apr 1, 2008 | 09:11 PM
crank ur gain up. if u want more power
i dont see the purpose of a new amp when u have this one only at half tilt
Old Apr 2, 2008 | 06:39 AM
ElVito1981's Avatar
yea i'll try that....I just thought that with 8V pre-outs from the deck, you shouldn't turn up the gain that high. You think I can turn up the gain to 75% without distortion?
Old Apr 2, 2008 | 06:42 AM
nismos14's Avatar
§è~® f®ÈÄk
75% should be fine, and the HU won't send a clipped signal probably up until peak volume.
Just be a little cautious with your volume setting.
Old Apr 2, 2008 | 08:00 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Also remember 60 is only a bit past half.
0-50 (or so) is in increments of 2, after that is increment of 1. So 0-50 is only 25 steps 50-80 is 30 steps.
Old Apr 2, 2008 | 08:37 AM
Fast1one's Avatar
Not to mention you won't get 8V with music anyway, so you can't just base it off that...
Most likely you will be getting 2-3V with music...
Old Apr 2, 2008 | 08:40 AM
nismos14's Avatar
§è~® f®ÈÄk
^ if that.
Old Apr 2, 2008 | 08:50 AM
ElVito1981's Avatar
when you say "volume setting" do you mean SVC? or what exactly?
Old Apr 2, 2008 | 08:51 AM
ElVito1981's Avatar
yea that's right..i remember you mentioning that don when you did my installation. Thanks
Old Apr 2, 2008 | 08:54 AM
nismos14's Avatar
§è~® f®ÈÄk
The volume level. Like 0-80.
Old Apr 2, 2008 | 10:30 AM
Fast1one's Avatar
^ if that.
Yup, thats at best...
If I were you I would leave my gains where they are and just crank the HU a little more, you'll be fine
Old Apr 2, 2008 | 11:55 AM
ElVito1981's Avatar
thanks guys!!
Wolf-Strong
53
Jul 28, 2006 11:36 AM
greg_atlanta
Mar 28, 2003 04:46 AM
JHZR2
Jan 24, 2002 04:05 PM
