Eclipse time-alignment
Old Apr 11, 2008 | 09:52 AM
ElVito1981's Avatar
Anyone have any idea how to use time-alignment on the CD7100 or any Eclipse? I am completely clueless. Thank you
Old Apr 11, 2008 | 10:04 AM
Torgus's Avatar
personally i think it's worthless. you need time alignment in large areas. in a car i find it hard to believe that your ears would be able to notice the sound waves traveling 2-3 feet further then the other...given how fast they travel.
Old Apr 11, 2008 | 12:31 PM
ElVito1981's Avatar
yea i just wish hi-end head units were more user-friendly
Old Apr 11, 2008 | 02:08 PM
Fast1one's Avatar
Its useful for other things...but people assume that they need to use T/A (and gobbs of it) to get a good center image...
Recipe for good soundstage:
  • Good install with minimal reflections (IE dash is a bad idea, kicks are a GOOD idea)...
  • 3 way is not necessary, but a good idea...
  • Independent L/R gains
  • Independent L/R EQs
All you need to do is gain match the left and right speakers to the left and right ears respectively. Then go to each band in the EQ and gain match each frequency using test tones or an RTA...
Don't believe me? Give it a try for yourself if you have the equipment and a good install...
http://www.diymobileaudio.com/forum/...ad.php?t=13888
Old Apr 11, 2008 | 03:32 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Dont forget about a bit of play with phase.
Old Apr 11, 2008 | 05:45 PM
Fast1one's Avatar
Most definitely...
There is a great tuning guide here: http://www.diymobileaudio.com/forum/...ad.php?t=33740
Simple, Effective...
Old Apr 14, 2008 | 07:53 AM
ElVito1981's Avatar
Ok, thanks...what about the gain though? The Eclipse claims to be 8V pre-out, but I've heard from some Orgers that it doesn't really put out that much for music. My Audison LRx2.9 has gain settings 1 thru 9, 9 being the loudest. What setting should I use to make the amp in sync with the Eclipse CD7100?
Old Apr 14, 2008 | 10:53 AM
Fast1one's Avatar
Just do it by ear...listen to an unclipped, but loud track and raise the gain until you hear distortion (or to the loudest, undistorted volume level you can handle), then lower it a tad making sure you have a decent amount of headroom...
Old Apr 14, 2008 | 01:28 PM
ElVito1981's Avatar
what volume level should I have the Eclipse when I'm doing that?
Old Apr 14, 2008 | 04:34 PM
Fast1one's Avatar
The consensus is usually 3/4 or 2/3 volume with most decks...
Old Apr 15, 2008 | 06:32 AM
ElVito1981's Avatar
Ok.....in my Audison instruction manual I saw a picture talking about the gain. It shows a head unit sending 5V to the amp, with the amp gain level at 6 of 9, and it says DISTORTION!! Does that mean that since my Eclipse is 8V, I should have the Audison at no more that level 4?
hawkdog
Apr 22, 2001 04:52 PM
RaYnMeLa
Apr 17, 2001 06:20 PM
wesley
Feb 2, 2001 01:31 PM
QUANSUNG
Dec 7, 2000 01:29 AM
