Adding Speakers to Bose System
Old May 27, 2008 | 02:58 PM
Saddles's Avatar
Currently have the bose speakers in my 2002, have replaced the head unit with an in dash dvd player and used the appropriate adapters. I was thinking about purchasing a 3rd set of bose speakers and installing them in my rear deck along with a set of aftermarket tweeters. I figure if I buy a set of front speakers, I can just give the bose amps power ground and source. Does anyone have any input on doing this?
Old May 27, 2008 | 04:10 PM
kpr10is's Avatar
Good god, this is wrong on so many levels that I don't know where to start.
Old May 27, 2008 | 04:24 PM
slickrick's Avatar
I would consider adding some 3" mid ranges to shake the c pillars...
Old May 27, 2008 | 05:01 PM
SuBXeRo's Avatar
uhhhh, well, i think that ur year has a central bose amp, so relocating the speaks shouldnt be too hard, adding more speakers? i dont see why you would even bother to be honest. What you are doing is one of those things where the oppurunity arises, but you are making the situation arise instead. I supppose you could do it, i dont think over all it would sound good, i would just leave it tbh.
Old May 28, 2008 | 11:15 AM
nismos14's Avatar
§è~® f®ÈÄk
[e_is_chillin]Please god do it and show these fools up.
Everyone thinks they are so high and mighty, f ya'll.
[/e_is_chillin]
Old May 28, 2008 | 09:22 PM
Saddles's Avatar
Im not using any preamp out puts as of yet, so theres 2 sets of those open...I was fairly partial to the way the 4th gen maxima speakers were in the back deck. The baddest sounding system in a maxima I heard was two sets of component speakers, one in front and the other in back. My model does have the sub in the middle stock, from what I've read although you hack up your child safety restraints, a 6.25in speaker should fit on either side.
My idea was to wire the speakers in the back deck and use them as the primary rear speakers, then run the stock rear door speakers off of one of the preamp out puts where I could adjust it down, possibly reverse that if I need further adjustment to keep from killing people's ears in back.
I was also planning on shaving the rear deck while it was out, either by creating another piece of fiber board with just the speaker holes cut or by rewrapping the stock piece. Then using bose speaker grills from a different year to cover the speakers in the deck.
Really my questions are, what are the 6? wires going into the front speaker amps, power, ground, tweeter + and neg, source and.. remote? Have I misread on my years about the availibility of space in the rear deck to house two speakers.
Will a 3in driver fit in the C pillar? There cannot be much mounting clearance under the panel if I remember correctly.
Old May 28, 2008 | 09:40 PM
slickrick's Avatar
Me and Kpr10is did extensive testing on the 3" idea and are actually in preliminary talks with AA to produce a custom ultra-light, ultra-thin 3" speaker to fit in the c pillar with no issues.
Old May 29, 2008 | 08:43 AM
Saddles's Avatar
A multi range speaker, or primarily bass, mid or high? While sitting in the drivers seat I just cant recreate the fullness of the sound that I had in my white maxima with my speakers in the deck. Keep me posted on your findings of the 3in woofer
Old May 29, 2008 | 08:44 AM
nismos14's Avatar
§è~® f®ÈÄk
This can't be freaking serious,
Old May 29, 2008 | 11:43 AM
kpr10is's Avatar
Great thread. Would read again.
Old May 29, 2008 | 02:26 PM
filtor1's Avatar
el oh el.oh el oh el. You could have picked a different company.
Old May 29, 2008 | 02:27 PM
filtor1's Avatar
To the OP. It is possible, but no benefit in SQ will become of your idea. Why are you trying to limit yourself to this scenario?
Old May 29, 2008 | 03:17 PM
slickrick's Avatar
I meant Adire Audio...
Old May 29, 2008 | 03:18 PM
slickrick's Avatar
Don't be jealous I am currently applying for a patent to make this design feasible...
Old May 29, 2008 | 03:29 PM
filtor1's Avatar
Ah, make that distinction next time. I know they went under but others may assume the more reputable company included in your funny.
Old May 29, 2008 | 03:30 PM
filtor1's Avatar
Almost 99% sure TB has already done this. As has Aura.
Old May 29, 2008 | 03:51 PM
slickrick's Avatar
ED copies everyone else...why can't I????
Old May 29, 2008 | 03:59 PM
filtor1's Avatar
Good question. One I think you learned about in ethics son.
Old May 29, 2008 | 04:13 PM
slickrick's Avatar
I plead the 5th...
Mar 12, 2020 12:06 AM
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
Need help
23
Oct 2, 2015 08:56 AM
A32goldylocks
Sep 2, 2015 06:39 AM
