Problem...
Old Sep 17, 2008 | 09:45 AM
Thakidmeen's Avatar
Problem...
I don' know whats up my speakers or my wiring, I have an Eclipse head unit with 4 kicker inside speakers and to 12' Kicker subwoofers and all of a sudden I get in my car 2day after class and nothing is working...the cd player and radio comes on but nothing comes out of the speakers "at all" could it possibly be a shortage??? It was workin fine the other day...then all of a sudden this happens...
Old Sep 17, 2008 | 03:12 PM
dnozzle2789's Avatar
do you have a 4 channel amp for the door speakers?
and is you're sub amp turning on at all?
Old Sep 17, 2008 | 03:47 PM
filtor1's Avatar
More information please. What amp or amps do you have. From the information you have given thus far it sounds like there are few things I would look at. First, your remote wire has a disruption in it. Second, is a fuse in the power line is blown. Yet another is your amplifier power or ground has a distruption, ei dissconnected or cut. Finally check the fuses on the amps. You can eaither take them out and visually inspect them or use a multi-meter to check for continuity(I recommend the latter as fuses can break and you can't identify the break visually).
Let us know what you find.
Old Sep 17, 2008 | 03:48 PM
filtor1's Avatar
Hey dnozzle, glad to have you around. Have you posted your system in the sticky yet.
Old Sep 17, 2008 | 05:19 PM
Thakidmeen's Avatar
Yes I do and no my sub amp isn't turning on at all...
Old Sep 17, 2008 | 05:21 PM
Thakidmeen's Avatar
I have the Kenwood KAC-9103D(1800w) for my Sub amp, and the Kicker KX350.4 (4 channel) for the speakers inside also have the converter...
Old Sep 17, 2008 | 06:36 PM
filtor1's Avatar
Check your main system fuse.
Old Sep 17, 2008 | 06:49 PM
Thakidmeen's Avatar
I'm sry if I sound like a noob, but how can I do that???I might have to hit up the car audio shop over here for help lol...
Old Sep 17, 2008 | 07:06 PM
navigator82's Avatar
check the ground maybe your not fully ground sand the ground of the wire
Old Sep 17, 2008 | 07:49 PM
filtor1's Avatar
The main system fuse is or should be located under the hood. The ground may or may not be run back under the hood depending on the installer.
Pop your hood and post a pic or two, we shall be able to guide you from the pics.
Old Sep 18, 2008 | 06:09 PM
Thakidmeen's Avatar
Funny thing is I got in the car 2day...and turned my cd player up and it was working>??????? lol, but I still need to know what the problem was, because I need to prevent this from happening again....
Old Sep 18, 2008 | 08:18 PM
filtor1's Avatar
There are some people here that are local to you. I am sure they would help you out if you ask.
Old Sep 20, 2008 | 01:09 AM
Thakidmeen's Avatar
Truly. Everyone on here has been a big help tho, thx4 tha reply's, anyone here from in the St.pete, Fl area????
nadir_s
Apr 15, 2003 09:51 PM
Cabowabo
Dec 11, 2002 02:02 PM
nadir_s
Jul 23, 2002 01:11 PM
lorddeceiver
Aug 6, 2001 06:23 PM
