Amplifier Cooling...
Old Jul 19, 2009 | 04:58 PM
shyheim07's Avatar
I've ran with the kicker ZX650.4 for two years, every time it gets hot it cuts off after a short time, but in the winter it's fine & at night...
I searched and seen a post of using a computer fan...
As anyone ever installed fans on the amp cover? I was thinking about installing two to blow air in and out put i would install them on the amp itself...
Old Jul 19, 2009 | 05:13 PM
nismos14's Avatar
§è~® f®ÈÄk
You could do that or turn the gain down slightly. That might just take care of your problem.
Old Jul 19, 2009 | 05:32 PM
shyheim07's Avatar
I have. It was at about a 1/4 the way up...turned it down and it still has cut offs...
Old Jul 19, 2009 | 05:38 PM
maxurlife's Avatar
My buddy installed two fans, push/pull effect. But he built an amp rack to do it. I think he had 4 amps at the time and probably used 4-6 fans. I don't remember. But I do know he didn't touch the amp itself.
Old Jul 19, 2009 | 05:39 PM
JNCoRacer's Avatar
Just the tip.
Post up if you do it. Ive got a couple fans here Ive thought about using also. Like you I only have the problem in the summer when its really hot.
Old Jul 19, 2009 | 06:15 PM
djfrestyl's Avatar
Suspension Yoda
Computer fans, cheap and effective.
Old Jul 19, 2009 | 06:26 PM
shyheim07's Avatar
I'm gonna try this out in Tuesday...I'll let you in on results
Old Jul 20, 2009 | 08:53 PM
doylerules826's Avatar
I moved my amp to right in the center of my trunk, where I could open up the trunk pass through and let it "breathe" a little bit. helped cool it.
Old Jul 23, 2009 | 12:12 PM
shyheim07's Avatar
It's done. Instead of the push and pull, i just did the pull (due to the size of the fan) Worked perfectly out here when it is muggy. The amp didn't catch any heat at all. I was suprise to bump around for one half hour and the amp still felt cool. No real tricks to doing this...
figure out how to open front cover of amp
find the best spot to cut a hole (size of your fan)
screw it on...and I suggest putting a relay on there
and your finished.
Old Jul 23, 2009 | 12:16 PM
nismos14's Avatar
§è~® f®ÈÄk
wow.
Old Jul 23, 2009 | 12:17 PM
JNCoRacer's Avatar
Just the tip.
How did you wire it? To a switch or just when the system is on?
Old Jul 23, 2009 | 12:26 PM
djfrestyl's Avatar
Suspension Yoda
Well, this is a first.
Old Jul 23, 2009 | 12:27 PM
shyheim07's Avatar
System turn on. I'm going to hook it up to a switch because it does get cool out here and it's not needed all year round
sliptap
Sep 30, 2015 05:57 AM
EdRomo86
Sep 12, 2015 07:49 PM
thenewguyy
Sep 12, 2015 11:12 AM
kirkhilles
Aug 8, 2015 10:53 AM
Maxima95GLE
Dec 7, 2000 11:02 AM
