8" Midbass woofe's choice for 08?
Ok org here goes. I have ID comps and coax in the doors and have some 6.5 beyma M6's in the rear deck. I just changed from an 300/4 for doors and a 300/2 for the beyma's. Well I want to put 8" for more midbass response as the beyma's are not performing to my liking. I do not plan to make a custom rear deck. I am just going to use stock locations, i am fully aware that will need a bit of work so no need to tell me that
I need some suggestions as to which 8"s to go with as these midbass will not be in a box, i am ASSuming i need some type of IB 8"s. If my reasoning is wrong here let me know. the 8" will be run in parrallel/series then run off the sub channel in the 500/5, Let me know what type of woofers you think i should go with and why. Thanks in advance
I know he said front doors, he said put it in the front and leave the rear deck empty. if i remove the 6's from the front door and the rear deck, i only have voice from the rear door's and i know my speakers in there will not handle it. I want the midbass as pure midbass. I could put 8's in the front doors and do some kick panels so that will help with the voice. Back to my main questions, I need 8's any suggestion?
thanks nismos14, i will look into those, I am gonna have to tie up the wallet a bit first. You are not the only one telling me to get rid of the rear deck, lol. I do like the idea of kick panels and the 8's in the doors. If i go that route (leading towards it) i have to decide do i keep the 6's in the door and build the kicks to hold 8's or vice versa. hmmmm. Ascendant i like your kickpanels, i am gonna need your help. haha.
+1 Dyn FTW!!!!!!!!
You could also look at dayton reference series if budget is a concern
http://www.parts-express.com/pe/show...number=295-366
Thanks Phxgold, not bad for 110 a pair, any first hand knowledge on these, they look like a beefy 8. Ascendant, i will put the 8's in the door once i have decided which ones to get. I am gonna need your help with the kick's, i know you have made a cople of sets already
homewrecker
09-23-2015 03:41 AM
