Radar Mounting
Old Dec 19, 2001 | 12:21 PM
4thgenguy's Avatar
Radar Mounting
Looking for IDEAS to mount my Radar detector. I don't want it to be very noticable from out side the car.
THANKS
Old Dec 19, 2001 | 12:28 PM
max'n out's Avatar
Mount the detecter out in the grill and the display where ever you want in the car. I think tweeter now sells kit's that alow you to do that easy.
Old Dec 19, 2001 | 02:02 PM
tbsmith's Avatar
form factor?
What kind of detector are we talking about here? If it's like most one-piece units, your best bet is probably to put it up high on the winshield near the rear view mirror. Either use a visor clip if available, or mount it with the suction cups in the same area. The only downside to this is that you have to reach up to turn it off if you ever get pulled over. That and the potential for a dangling cord. Personally, I've decided that a one-piece detector can't be mounted ideally if you want to maintain a low profile. It has to be able to see out of the car. That's why I'm looking into a remote unit. That or a V1 w/remote display, but I can get a BEL remote for less $$. I've never heard of retrofit kits to remote-mount a regular detector, but if they exist I think that would be the next best thing. With that, I think it really depends on whether or not the retrofit degrades quality.
Tim
Old Dec 19, 2001 | 04:38 PM
4thgenguy's Avatar
It is a cobra 9200(one piece unit). I was thinking about taking it apart and mounting the unit in grill area and running the cables for the display through the engine compartment and mounting just the switch and display in the car. Has any one done this will I lose effectiveness of the unit?
Old Dec 19, 2001 | 04:42 PM
max'n out's Avatar
If you look above you can see that I suggested it. Yes it makes it more affective. There is also one out now that you don't have to disasemble you just mount the senser out front and the display inside.
Old Dec 19, 2001 | 05:00 PM
4thgenguy's Avatar
I'll Check out tweeters and see If i can find one.
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
