Need Amp Advice for 2 12inch Subs info inside thanks
Powerbass B-series 12" subwoofer, 250W (rms), Dual 4 Ohm VC
Basic Features
# Backplate: Bumped and Dip Cut Back Plate
# 12 inch woofer with black cosmetics
# 50 oz magnet
# Advanced Polyproplene Cone
# Black Top and Back Plate
# Customized Rubber Boot
# Oversized Control Surround Design (CSD)
# Rigid Black Frames
# Pole piece: Vented Pole Pieces
# Spectrum Analyzer: Progressive Flat Spiders
# Voice Coil: Dual 4ohm VC
# Voice Coil: Multi-Layered Voice Coils
Specifications
# FS= 29.8HZ
# QTS=0.78
# VAS=118.9Hz
# Frequency Response: 30 Hz - 1 KHz
# Peak Power (Maximum): 350 Watts Peak
# RMS (Continuous) Power: 250 Watts
# Sensitivity: 87dB @ 1W/1M
I have 2 subs and now need a amp to power them.
I do NOT know how to calculate the rms and peak to get the answer i need.
All i know is the guy i got these from said he used a 1000 watt 2ch amp and
since he didnt know what was the info the subs i did some research and found
the above info so i just want to make sure i dont under/over power them
What size amp is recommended to push these?
thanks
Basic Features
# 50 oz magnet
Specifications
# FS= 29.8HZ
# QTS=0.78
# VAS=118.9Hz
thanks
Basic Features
# 50 oz magnet
Specifications
# FS= 29.8HZ
# QTS=0.78
# VAS=118.9Hz
thanks
Basic Features
# 50 oz magnet
Specifications
# FS= 29.8HZ
# QTS=0.78
# VAS=118.9Hz
thanks
Your spec 250 watts is per coil, so your single sub require 500 watts when using both coils, times that by 2 and you will need 1000 watt true rms amp to push the subs. You might also think about upgrading alternator as well unless you already done so???
Listen to Ricksi......you dont need a 1000w rms amp, 500w rsm will do plenty. you can always get a 4channel amp and bridge two of the channels for a little more power or just go with a nice mono block class d amp and run them together it all depends on the sound that you want.....
I guess those speakers could be 125 watts rms per coil? I was thinking that they were 250 coil thus my suggestion for 1000 watt rms amp.... If he does go 1 ohm amp I say look for old school Orion HCCA amps!
I am running 800 watt amp for my Alpine Type R 12, dual 4 ohm vc and when I have my volume turned up my lights does dim. Am thinking about adding a Cap to see if that will help with the dimming! In theory it should?!
I hear alot of peeps saying not to use a cap, why is that? From my electronics background cap is a good thing! So I thought! lol
Do the big three for sure. If your alternator isn't making enough to power your amp adding another component that needs to be charged can actually strain the electrical even more, very few applications can benefit from a cap in a car. Right now I'm running ~2200 Rms on a stock alternator (Not a good idea if you like your alt) waiting on a 250 amp replacement. But even at this high wattage dimming is minimal. I have ALL 0 gauge wire. I have run 1300 Rms with no dimming at all.
Dimming is minimal but you can notice it. I am running Memphis amp, it is better than the JL Audio 800 watt amp I had.
Cadence zrs 9 and a cadence zrs 4. http://forums.maxima.org/audio-elect...ild-3-10s.html
damn sorry i almost forgot i started this thread lol thanks for the responses fellas. well budget wise i been lookin on craigslist for a used amp under $150 lol since i picked up the box and 2 12's for $100 later ill upgrade but for now this will work for me but if new i'd say $300 max. but i want the full potential i can get out of these subs thanks
i found a used kenwood kac-9103d for $80 will this work specs below
mono subwoofer amplifier
500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
1-ohm stable (no power ratings available)
CEA-2006 compliant
variable low-pass filter (50-200 Hz at 24 dB per octave)
bass boost (0-18 dB at 40 Hz )
subsonic filter (15/25 Hz, 18 dB/octave )
top-mounted controls
Class D design
speaker- and preamp-level inputs
preamp outputs
fuse rating: 30A x 2
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
14-7/8"W x 2-9/16"H x 11-1/2"D
warranty: 1 year
CEA-2006 compliant
Class D design
preamp outputs
warranty: 1 year
CEA-2006 compliant
Class D design
preamp outputs
warranty: 1 year
CEA-2006 compliant
Class D design
preamp outputs
warranty: 1 year
ok found some more amps according to the specs of the subs im using which amp below is best for it a 2-channel or mono the SONY & KICKER are mono and KENWOOD& LANZAR are 2 channel?
SEE SPECS BELOW
SONY XPLOD
1600W max power
500W x 1 into 4 ohm, 20Hz - 300Hz, @ 0.2% THD
900W x 1 into 2 ohm, 20Hz - 300Hz, @ 0.6 THD
Class D
Variable 50 - 300Hz 12dB/oct Low Pass Filter
40Hz EQ Boost
RCA and Speaker Level Inputs
Kenwood mono subwoofer amplifier
300 watts RMS x 1 at 4 ohms (500 watts x 1 at 2 ohms)
CEA-2006 compliant
Class D design
preamp outputs
fuse rating: 40A x 1
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
12-7/16"W x 2-1/2"H x 11-11/16"D
warranty: 1 year
Kicker KX600.1
Power Specifications - Full Range Channels
RMS Power @ 4 ohms 300 watts x 1 channel
RMS Power @ 2 ohms 600 watts x 1 channel
RMS Power @ 1 ohm Not Stable
Bridged RMS Power Not Bridgeable
Peak Power Output N/A
Amplifier Specifications
Number of Channels 1 - Mono
Total RMS Power Output 600 watts
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power 0.5%
Speaker Level Inputs Yes
Preamp Outputs 1 pair
Built-in Crossover N/A
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 50 - 200 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 95 dB
Channel Separation N/A
Bass Boost 0 - 18 dB (40 Hz)
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 30A x 2
Lanzar VCT2110
Number Of Channels: 2
Maximum Power: 1000 Watts
Low Frequency response: 15 Hz
High Frequency Response: 30000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
500W x 2 Output @ 2 Ohms
1000W x 1 Bridged Output @ 4 Ohms
General Features
2 Ohm Stable
MOSFET Power Supply
Variable Hi-Pass :40 Hz-250 Hz
Variable Low-Pass : 40 Hz-250 Hz
Variable Input Level (Gain) Control : 6V-200mV
Bass Boost Selector : 0/+18dB
Thermal / Overload / Short Circuit Protection
Soft Turn On/Off
Power & Protection LED Indicator
Low Level RCA Input: 10K Ohms
Line Level RCA Output
Frequency Response : 15 Hz-30K Hz
Signal to Noise Ratio: >95dB
THD:0.1 %
2x30 Amp Maxi Type Fuse
Slim Size Amplifier Design For Easy Installation
Dimensions: 10.63''W x1.75''H x 9
SEE SPECS BELOW
SONY XPLOD
1600W max power
Class D
40Hz EQ Boost
CEA-2006 compliant
Class D design
preamp outputs
warranty: 1 year
Kicker KX600.1
Subsonic Filter N/A
Fan Cooled Yes
Fuse Rating 30A x 2
Lanzar VCT2110
General Features
2 Ohm Stable
MOSFET Power Supply
Soft Turn On/Off
THD:0.1 %
J2FRESH: Take a look at this cadence. http://www.woofersetc.com/p-6027-zrs...amplifier.aspx Wire your subs to 4ohm and bridge the amp to get 500 rms.
Voice coils wired in series, speakers wired in parallel for a load of 1.34.
1st or 2nd pic
so wire them like this
or this
