Bose alpine help
Old May 22, 2011 | 09:07 AM
T.One's Avatar
Bose alpine help
Okay so replacing my hu okay? Im getting sound frOm all speakers but barely audiable at full blast on new alpine flipout. Any idea why? Or maybe the bose amps actually not
On
Maybe?
Old May 22, 2011 | 09:13 AM
T.One's Avatar
Okay jus realized no matter how low or high volume is. It sounds the same
Old May 22, 2011 | 10:41 AM
nismos14's Avatar
§è~® f®ÈÄk
Need more info, which harness did you use? What is the pre-out voltage of the Alpine you used?
Old May 23, 2011 | 12:38 AM
T.One's Avatar
preout is 4v. used a regular harness from best buy. found out today the external amp is not sending out the volume on any channels. I tested this with a regular 4ohm speaker. So this means the Bose amp is turning on, its just the signal is not coming out from the alpine amp.
The headunit is a iva d900. expensive as hell system.
It has an external amp that works just like any headunit. all the wires on the harness are exactly the same as a harness off the back of a normal head unit.
It has all 4 channels hooked up. every wire except a pink/black one and orange one is hooked up to the bestbuy harness. you can hear sound, but it sounds like ear buds playing moderate music.
Old May 24, 2011 | 01:50 AM
T.One's Avatar
Nothing?
Old Jun 3, 2011 | 07:07 AM
The8thSt's Avatar
You shouldn't need the external amp to feed the bose amp.
The headunit should have yellow, red, black, blue, blue/white hooked up like normal, but speaker feeds should be fed from the RCA preouts instead of the speaker level outputs from the external amp.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
