when mounting my amp...
Old Dec 30, 2001 | 06:56 PM
Daddy Fat Sacks's Avatar
when i mount my amp under my seat where should i ground the negative cable. also, how can i mount my sub box so it doesnt slide around the trunk? gracias
Old Dec 30, 2001 | 07:22 PM
maximadave's Avatar
detailerdaveb@gmail.com
Re: when mounting my amp...
Buy some "L" brackets at your local Home Depot, Mount one side on the box and the other to the floor of your trunk. Your ground wire should not be more than say 6" away from your amp. Ground it to chassis.
Old Dec 30, 2001 | 10:27 PM
i mean somebody that has an amp under their seat, what screw did you ground it to or howd you ground it cuz i tried the seatbelt screw and that aint work
Old Jan 2, 2002 | 02:28 PM
Pit5Bull's Avatar
Grounding the amp…
daddyfatsacks,
Correct me if I'm wrong, but did you try to ground the amp to a bolt in an unpainted area? I haven't gotten up under there yet, but I'm pretty sure that you'll have to find one fitting that description, or 'make' one by scraping away some paint around a bolt. There should be at least two bolts under there somewhere that you could use as a grounding point.
Good luck!
peace2u
Old Jan 3, 2002 | 07:33 AM
thanks yo
Old Jan 3, 2002 | 02:54 PM
Matt93SE's Avatar
STFU n00b!
usually I just remove one of the seats, sand around a bolt hole on it, then attach the ground cable to it. mask around it, then paint over it with black paint so it looks better.
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
