Replaced my 4th Gen Maxima Speakers
Changed my front speakers seeing how only one was working....It was a easy install, & the speakers sound great, so I'll let this pics speak for themselves.
Thanks but uh...how come? & I also want to know how do you tell the difference between the positive & negative wire in the door? I couldn't tell the difference & when I play from certain sources the left speaker sounds louder than the right
3 reasons.
1. Sound quality. Resonance. Plastic reflects sound waves and resonates/vibrates. So does your metal door frame. MDF is a dead material, pretty much absorbs sound waves, or at the very least, vibrates much less, speakers sound better.
2. Easier to mount speakers to MDF than spend the time to hack up your speaker and fish around for a mounting point in the soft plastic.
3. Your OEM speakers wouldn't be butchered, and you can return to stock, or sell those speakers any time you want.
I have the positive/negative wire colors memorized. But when I don't, I use a multimeter to determine which OEM wires are positive/negative.
These are the reasons I was telling you to have me do the work. Yea, you got it done, but you're missing the finesse and the other 40% of the knowledge to make it a really quality install, no offense.
3 reasons.
3) The OEM speakers were completely blown with the coning & all out
Makes sense. You probably won't notice a difference in sound if you switched to MDF rings. You might as well save yourself the few bucks for the rings since the speakers are already installed. It's only in larger/more expensive installs that it makes a difference. Still a practice I bring to all installs though.
When you check your wiring, wrap the leads in electrical tape. Something might be grounding out against the metal door.
Lakersallday24
Nov 7, 2024 07:31 PM
jskirwin
Jun 8, 2016 08:49 AM
morteljc
Oct 19, 2015 10:47 AM
