Bose door speakers...no luck
Old Jun 7, 2002 | 07:03 AM
DigitalTexan2u's Avatar
((I've used the search function and my questions weren't answered))
I've got a '97 SE and the *2* door speakers (midrange, and tweeter) don't work! I took the door panel off and made sure the connections were good...they were.
Any ideas? Does it sound like a speaker/head unit/ or wire problem?
Also how would I check to make sure power was getting to the speakers...would a regular "test light" work?
ANY HELP WOULD BE GREATLY APPRECIATED!!!!
Old Jun 7, 2002 | 08:41 AM
Kevlo911's Avatar
Kevlo for President
Re: Bose door speakers...no luck
this happen to my car a few years ago, my drivers side door speakers would not work, but my pops took it to the dealer when i was in school so i don't know what they did to it
Old Jun 7, 2002 | 09:05 AM
96SE5Spd's Avatar
I had the same type of problem but it only happened when I hit a bump there may be some sort of ground problem or the amps that power the speakers may be bad use a DVOM(digital volt ohm meter)if you can get one to test the speaker conections. You can test resistance with that to see if it is connected right, but when you use the meter make sure the power to your car is off.
REDinLV
Aug 15, 2024 12:30 AM
howardis
Dec 11, 2019 06:10 PM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
lrb6805
Sep 24, 2015 05:03 PM
