Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
understeer!!! help!!!
Old Aug 1, 2005 | 06:35 PM
hardcorefubu's Avatar
i just added a the progress rear sway bar to my 00 max and i get more understeer then i previously did when i didn't have it on. my current setup consists of tokico illuminas, tein s-techs, stillen front and rear strut bars, and progress rear sway bar. my struts were set at 4 all around but i chaged it up to 5 up front and 2 in the rear. this helped with understeer quite a bit but not enough. any suggestions? maybe adding a stage II front tie rod from matt blehm Co. to stiffen up the front more?
Old Aug 1, 2005 | 10:18 PM
Blade_99SE's Avatar
Wow. You have a lot of things to work with. First I would try setting my front struts to their softest setting and the rear struts to the stiffest setting. Next set your tire pressues to 35 psi all the way around. Then test your cars performance. See how bad/good your car performs. and go from there. Next I would go +5 psi in front and -5 psi in the rear and/or stiffen the front shocks.
The way to setup a front drive car is to lossen up the front and stiffen the rear. Your tire pressures will affect your traction an responsiveness.
Old Aug 2, 2005 | 04:31 PM
irish44j's Avatar
retired moderator
RSB causes oversteer, not understeer. You can counteract the RSB with an LTB, which will bring it back to slight understeer, depending on your other suspension/tire settings....
Maximam
May 27, 2003 10:58 AM
bonzelite
May 7, 2003 05:49 PM
NotNew!!NewSN!!
Apr 13, 2002 11:45 AM
ne max
Feb 4, 2002 06:01 AM
gareno
28
Oct 19, 2000 04:38 AM
