Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
when is the clay bar done?
Old Jul 11, 2005 | 06:42 AM
jaedaliu's Avatar
I was claying the hood of my max, sprayed the lubricant thing, wiped the clay bar over it, and the clay bar was sliding really easily, so i folded the bar, and moved onto the next section of the car.
I then polished the car, and waxed it. Then I noticed the car was still bumpy. I was afraid that I had used too agressive of a polish, but decided to test the simplest thing.... re-claying a rough area. the bar got dirty again, the surface got smoother, I was definitely pulling more junk out of the paint. (does this mean my wax needs to be thicker?)
so, my question is, how do I know if I'm done claying an area? when it's wet with lubricant, it seems smooth with the clay bar? am I supposed to run my fingers over the paint to check for done-ness before moving on to the next section?
hope someone can edjumacate this
Old Jul 11, 2005 | 05:12 PM
Bluesbrekr's Avatar
Doctorate in Detailing
With experience you'll be able to tell when the clay bar had cleaned and area. Until then you can check by gently running your fingers over the area that has been clayed and dried. It should feel very, very smooth. If not, use the clay and lubricant again.
Old Jul 11, 2005 | 06:02 PM
PrinzII's Avatar
OG and counting...
Usually, if the bar slides effortlessly across the finish with lube on it, that means the clay bar has done its job. When you are claying, you hear a sound similar to filing your nails if there is still contamination on your finish.
Old Jul 13, 2005 | 09:38 AM
scopium
when u clay bar.. usually after each section i wipe down the area with a clean rag and run my hand on it.. if it feels like a babys butt then its done if not.. i clay it again.
gman214
Sep 25, 2015 03:03 PM
followthadollar
Sep 23, 2015 08:31 PM
Stagnet04
Sep 14, 2015 11:28 PM
