Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
headlight cleaning problem
Old Apr 19, 2006 | 03:13 PM
xlcrew's Avatar
I’m Back
i used whazzzup'z write up for cleaning my headlights today. well i have one that will not clear up. i wet sanded it and i'm using meguires scratch x and i can't get it to clear up. any suggestions?
Old Apr 19, 2006 | 03:55 PM
doublea's Avatar
I bought that kit: http://www.caswellplating.com/buffs/plasticbuffkit.htm
With this you can use your bench grinder to polish lots of different material, I've polish my 2k2 HID housing, the result is simply amazing. I was able to remove all the haze and scratches, I made those baby shine. You can also buy each product separately, but in order to do a good job you need 2 set of the loose cotton, canton flannel + white, blue compound and your set to make an incredible job.
Old Apr 19, 2006 | 04:52 PM
qballjr13's Avatar
[QUOTE=xlcrew]i used whazzzup'z write up for cleaning my headlights today. well i have one that will not clear up. i wet sanded it and i'm using meguires scratch x and i can't get it to clear up. any suggestions?[QUOTE]
Thank you for posting this...mine isnt as bad as yours but I cant get it totally clear either. I wet sanded all the way down to 2000 grit and then used the Scratch-X, but your right they are still not super clear. Any other suggestions since I dont have a bench grinder??
Old Apr 19, 2006 | 04:57 PM
k2max_driver's Avatar
get a buffer or find a detailer that will do it for you all it takes is a couple passes with rubbing compound at high speed. you can't get the compound hot enough with your hand to work correctly.
Old Apr 19, 2006 | 10:17 PM
kbohip's Avatar
I know this is probably going to be a no, but is this kit able to remove small rock pits? My headlights are riddled with them from the stupid traction rocks they throw down on the streets here in winter.
Old Apr 20, 2006 | 12:59 AM
XyNoix-HIC's Avatar
that piece of doodoo is soooo expensive! jus to clean the lens? i don't think its worth it. I went to Napa and got this spongy thing that you put on your drill and buff away the yellowness, it worked well....but its not SUPER clear, but its better than spending 130 dollars damn! that thing was only 10 bucks!
Old Apr 20, 2006 | 04:44 AM
doublea's Avatar
The caswell kit are use by pro's, so I understand if you only want to polish your headlight find a guy who has the kit and he'll do it for you. I bought that kit with a bunch of other compound so I can polish virtually anything, and that pay for itself.
Kbohip, if you are patient enough you can remove deep scratch, you have to understand that with deep scratch you have to buff with a cutting compound ( white ) and the faster your buffer spin the less time it's going to take to remove it. That product work beautifully, it's more costly but you'll have enough compound to buff your entire neighbourhood's headlight.
Old Apr 20, 2006 | 04:57 AM
MAXRB8's Avatar
What about Mother's powerball and Mother's plastic polish?
Old Apr 20, 2006 | 08:32 AM
igzy's Avatar
I Know Kwaliti
I used Mother's plastic polish on mine... Passenger side headlight was new (replacement after incident with truck tire) and drivers was old and scratched up... I applied the polish and rubbed it with cloth and it made them look almost the same... I picked up a bottle of it from eBay for $10... I find it that it works well on smaller surface scratches, if you have larger deeper scratches this may not be the right thing for you... I tried it on my fog lenses and they are quite scratched up and it made some improvement but is far from what I would like it to be...
Old Apr 20, 2006 | 09:49 AM
MIXXMAX's Avatar
I use Meguiar's Mirror Glaze clear plastic polish and it works wonders! I'm not sure if they still sell it because I haven't seen it in the stores since I had bought a bottle a couple of years ago. It really makes the headlights and other plastics shine.
Old Apr 20, 2006 | 10:00 AM
qballjr13's Avatar
I'll have to keep my eyes open for that stuff. I have the Maguiar's Scratch-X but I will look online right now for that stuff.
EDIT: Maguiar's has it on their site so you can still order it. They have a vendor search but its split between "Consumer Products" and "Professional Product". The Clear Plastic Polish is concidered a "Proffesional Product" which is carried by different vendors (not Wal-Mart, Target, CrAP...etc)
Old Apr 20, 2006 | 01:15 PM
XyNoix-HIC's Avatar
i Think this thread should get moved to the cosmetic section
Old Apr 20, 2006 | 02:57 PM
i30ish's Avatar
can you give the link to thewhazzzup's writeup? thanks!
Old Apr 20, 2006 | 10:25 PM
VQuick's Avatar
Chassis Freak
http://forums.maxima.org/showthread.php?t=443410
Old Apr 21, 2006 | 07:25 AM
jbelosic's Avatar
This site has lame music to it, but their product is awesome. I've used it on my E430. Read the testimonials page- http://www.lensrenew.com/
Old Apr 23, 2006 | 08:09 PM
2 MaXiMuS 4's Avatar
Maxima.Org's Official Lurker
try some blue magic plastic polish or Meguiar's PlastX and then some Klasse AIO - Thats what I used after wetsanding my brother's headlights on his mustang. Came out beautifully.
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
intimidator
Sep 5, 2015 07:23 PM
sdotcarter
Sep 2, 2015 09:53 PM
iflexsteel
Sep 2, 2015 08:04 AM
