Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Went to the dyno today
Old Feb 23, 2006 | 05:08 PM
crispykid717's Avatar
Bigger than Jesus
Went and got my 02 6 speed dyno'd today. I was pleased with the numbers but would like some feedback.
All 3 pulls were done in 4th gear...
Run 1: HP=213.16; TQ=217.83
Run 2: HP=213.66; TQ=215.63
Run 3: HP=206.07; TQ=217.83
A/F ratio ranged from 16 to 13.
My mods are: modified Injen intake, Cattman y pipe, Cattman b pipe, stock muffler.
Based on my mods do these #'s look good to you guys? This was my first time going to the dyno. I have heard people requesting run files. I did not get any of those but how would I go about getting them? Thanks in advance.
Old Feb 23, 2006 | 05:43 PM
NmexMAX's Avatar
dot dot dot ...
You have to ask the shop for the run files.... pretty simple.
What was the correction factor? What were the conditions? Any weird humps/spikes? Was this on a dynojet?
#'s look a smidge on the low side IMO.
Old Feb 23, 2006 | 06:10 PM
Bigger than Jesus
Finally got to scan the dyno graph into my computer.
Old Feb 23, 2006 | 06:16 PM
NmexMAX's Avatar
dot dot dot ...
Not bad.. typical..
Well, lessons learned for next time.....get the actual files, and tell them to take it to fuel cut.
Old Feb 23, 2006 | 07:04 PM
Hoooper
cant see pics
Old Feb 23, 2006 | 08:44 PM
Puppetmaster's Avatar
I can't see the image, but the numbers look slightly low compared to what I've seen. MaximaDave had 217 whp and 221 tq (SAE) with Berk intake, Cattman y-pipe, Powertech exhaust, 18" Alessios, but then it can vary so much between cars and conditions.
See if they can email you the run files or if you can go back to the shop with a flash or floppy to get em.
Old Feb 24, 2006 | 06:17 AM
HotshotVQ35's Avatar
i did 218/228 with frankencar intake, and cattman y-pipe on a dynojet
Old Feb 24, 2006 | 08:14 AM
Bigger than Jesus
The guy at the dyno place had me run the car myself so I don't know if I did it exactly correct. I would get it up to fourth gear then floor it up to redline and when it got to redline I would just let off the gas and throw it in neutral. Should I have just kept on the gas until I hit the rev limiter and let the car shut itself down? Do you guys think I could gain anything from tuning with SAFC? Or should I just wait until I get headers this spring?
Old Feb 24, 2006 | 09:23 AM
Considering how often our tachs are off, yes.
Adjusting your AF depends on what it looks like now. But with headers, more likely that not, you'll need to use some sort of piggyback.
Old Feb 25, 2006 | 12:19 PM
NYPD-Arnold's Avatar
Z
Shouldn't he have pulled and redlined in 3rd?
Old Feb 25, 2006 | 07:16 PM
For the 6MT, 4th gear is right because typically you want to use the gear that has its ratio closest to 1.00.
Old Feb 26, 2006 | 08:16 PM
Z
Oh. Dur I forgot he's 6spd. Reading ftw!
Old Feb 28, 2006 | 07:06 AM
Ghase's Avatar
It not that bad, but you'll pull better with one of these.........
www.flickr.com/photos/29514562@N00/ only fit it can if..LOL
And yes that's mine!!!!!!!
Old Feb 28, 2006 | 02:21 PM
Hoooper
Originally Posted by Ghase
only fit it can if
arright yoda
and no, it wont fit
Old Feb 28, 2006 | 06:31 PM
jman7777's Avatar
im probably a retard but shouldn't those numbers be higher? like 10-15 higher for each. 255hp output... factor in DT loss etc etc... wouldnt those numbers be like ~220's?
Old Feb 28, 2006 | 07:43 PM
Hoooper
not that i know of. theres also a dyno machine loss, and the average for a 6spd seems to be around 205.
Old Mar 26, 2006 | 03:45 PM
Z
Late to reply, but...
No. VQ35 in 2002/03 Maxipads is overrated. It has 245HP, not 255.
howardis
Dec 11, 2019 06:10 PM
Forge277
Jun 13, 2016 09:26 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
