Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
My 2000 Max SE Auto Dyno results.....
Old Mar 14, 2013 | 06:33 AM
  #201
MoncefA33's Avatar
I think i want to squeeze about 230whp out of mines n im good
Old Mar 14, 2013 | 08:18 AM
  #202
2kMaxim's Avatar
I thought the older the car the more fun to mod?.... Wouldnt wanna devalue a 1yr old car n have something go wrong with that now do u? Lol... I understand u though, ur pretty much at ur goal with this car, thats cool.... I think i want to squeeze about 230whp out of mines n im good
Very possible with full boltons.
.....and a 50shot
Old Mar 14, 2013 | 08:22 AM
  #203
MoncefA33's Avatar
.....and a 50shot
Old Mar 14, 2013 | 11:01 AM
  #204
NmexMAX's Avatar
dot dot dot ...
Look at my lame auto dyno graph man.....there's not even distinguishable readings below 3-3500rpms What the heck do I need 24 points of tuning for?!
Exactly my point, SAFCII, leaves you with more options later..
Once you get to playing, you'll see because you've never done it, a few extra points help. I run out of points and I only have 12, and I also have an auto that gets dynod from about 3700-7100. I only use 2 - 3 points past 6500 so don't give me that either. Also, adjusting before 3000 or 3500 seems pointless, it's after 4000 which sees the most gain.
Better resolution is good, but a larger MAF housing option and ease of install is also good.
Old Mar 14, 2013 | 11:03 AM
  #205
MoncefA33's Avatar
Are you still worrying about SAFC vs VAFC?
VAFC wasn't even designed to work with cars that use a MAF sensor. Get an SAFC, it's easier to tune, does the job, and has a higher ceiling for power.
Old Mar 14, 2013 | 11:14 AM
  #206
NmexMAX's Avatar
dot dot dot ...
Ceffy to the rescue ..
Old Mar 14, 2013 | 02:05 PM
  #207
2kMaxim's Avatar
This is why so many people are confused The forum is literally divided in half on what to get.....lol.
I did some hard driving today to teach the ECU a good relearning lesson after solving my little "SWIRL solenoid" issue (which turned out to be that the mechanic didnt fully push in the wiring harness in till it clicked).......
One thing i payed specific attention to was shift points. When under WOT acceleration in my car the needle drops to about 4200rpms after every shift. The VIAS doesnt even click over till what, 5000? If you study my dyno graph, you can see that the vias doesnt just bump up a couple of ponies......use the HP lines and its literally a 10-12hp/trq bump. Scientifically it would be very advantageous to have this be activated at 4k rpms, just under the shift point... so that under WOT it would have the better breathing valve setup every shift. The only way I can do this is with a VAFC. I can see NMex's point about VAFCII over I ......on ebay you can find used II's for right around $200.
I really think using my dyno data...its worth shifting that VIAS activation point back. I also did all sorts of "daily drving" scenarios today...and none of the even come close to raising the needle to 4k..... Basically if im revving to 4k i MEAN IT. Seems like a pretty sound logical plan to me.
Many people are using the VAFC on their max's and its working......and they are able to shift the VIAS point around...so is it potentially not working even a discussion anymore? So much conflicting info!
.....lol
Old Mar 14, 2013 | 03:34 PM
  #208
NmexMAX's Avatar
dot dot dot ...
Get a VAFC, Dyno with it completely open, and completely closed, overlay the graphs, change your VIAS switch, done. Also, that bump early on in your dyno is the torque convertor locking up (3200-3500), as was stated by Moncef, so it's false data.
http://forums.maxima.org/all-motor/3...e-removed.html
Example:
200 RPM isn't enough for me to get a VAFC.
Here are my dyno adventures.
http://forums.maxima.org/dyno-discus...no-thread.html
Old Mar 14, 2013 | 04:15 PM
  #209
2kMaxim's Avatar
Yeah.....it appears from all the data that 4000 rpms activation might be too aggressive....4500 rather than the factory 5000 seems to be the answer. Im a torque freak so taking the rod out isnt a good solution for my needs. That might be the move id do with a MT......cause I could wind the crap out of it all the time...lol
But you are saying to this that its probably not worth VAFC for those 500rpms?
Unfortunately VAFCII seems to run cheaper than SAFCII...
Old Mar 14, 2013 | 05:14 PM
  #210
Grand_hustle17's Avatar
SAFC gets my vote... moncef pretty much summed it up
Old Mar 15, 2013 | 06:14 AM
  #211
MoncefA33's Avatar
You need to stop worrying about adjusting the VIAS.
Nissan engineers already did the work for you. If you open it later, you will lose area under the curve. If you open it earlier, you will lose midrange torque.
The SAFC will help you make more actual power, because it is made for cars that have a hotwire airflow sensor, like ours, instead of a pressure sensor, like the VAFC. You will experience this when you want to slap on a large MAF housing on the car and the SAFC will scale it in 2 seconds as opposed to making your car undriveable like it would with a VAFC.
Old Mar 15, 2013 | 11:07 AM
  #212
carsnwomen91's Avatar
This I didnt know :S so how is it able to successfully change my af's if it wasnt designed for my maf sensor type?
Old Mar 15, 2013 | 12:21 PM
  #213
MoncefA33's Avatar
It still intercepts your MAF signal and plays with the voltage going into your factory computer, since it understands the raw voltage signal. This allows you to change AFR in open loop.
However it does not understand rescaling for the larger cross sectional area of a larger MAF, such as a Q45 or similar, across closed and open loop because a MAP sensor does not monitor load that way in the first place.
Old Mar 15, 2013 | 12:32 PM
  #214
O ok maf scaling but otherwise it's the same, nvm i thought you meant somethin else
Old Mar 21, 2013 | 05:13 PM
  #215
.....and a 50shot
been done before without nitrous...
Old Mar 21, 2013 | 10:31 PM
  #216
2kMaxim's Avatar
I be VERY impressed to see those numbers on an NA Auto. Fully bolton 5 speed with cams and such i wouldn't be shocked.
Old Mar 22, 2013 | 05:39 AM
  #217
Car made 239 with no cams.... Also even 2 4th gens here untuned made upper 220's... But idk if the big laughter was to hurt pride because of something that was done already but eh... This place has changed, not in it to impress anybody nomore.. just in it to enjoy my anti drug, which is modding the car, if i dont get to 230's then so be it.... I can see if there was this hoop dream to get to dandymax numbers of 280whp but i dont see how 230's is sooooo impossible... plus a cammed motor is still naturally aspirated (NA)
Old Mar 22, 2013 | 05:42 AM
  #218
Plus i am a 5mt
Old Mar 22, 2013 | 06:35 AM
  #219
NmexMAX's Avatar
dot dot dot ...
No one sticks with the DEK any more. Couple of peeps went all out then bailed before they finished.
Sloppymax had a nice auto set-up, and it was very simple.
DrunkieBear had potential, but as I said, he bailed. Don't blame anyone for moving on to a different/better platform, more cost effective.
I look outside the box, shti look at my vehicles. Who mods a Maxima, who lifts a Pathfinder?
I always hear "You coulda spent half and been 2x as fast or as high". I say, anyone can mod a "____" , but I didn't.
Old Mar 22, 2013 | 07:24 AM
  #220
MoncefA33's Avatar
I stuck with it, in spite of the people who d1ckride the VQ35 and the swaps etc. Pushed the DEK to the bitter N/A end and made decent power.
Old Mar 22, 2013 | 07:49 AM
  #221
NmexMAX's Avatar
dot dot dot ...
Yeah you and Dandy were/are the only ones, most bail.
Old Mar 22, 2013 | 09:05 AM
  #222
i dont blame them for going with the 3.5 because it does have more potetial.. if it was 2 or 3yrs ago there wouldve already been a 3.5 in here... or just keep my 3.5 lol... im not really attacking times and numbers anymore, however just setting what i think is a modest and reasonable goal and having fun getting there, there is absolutely no competition here or around so there is no motivtion, its either stanced cars or guys that moved on to cars coming 12 seconds off the show room, dont care to compete with that, just enjoying what i have for the time being
Old Mar 22, 2013 | 10:02 AM
  #223
2kMaxim's Avatar
You have no idea how often i hear that. Most people cant even really picture what a maxima looks like in their head so they just go by wherever they've seen the name. "Why are you messing with exhaust/mods on a maxima?" Kind of irritated me at first but now I just realize they dont know how great the engines are and how sharp the 5th gens look. Whenever im returning to the parking lot, seeing my car always makes me smile.
Old Mar 22, 2013 | 12:46 PM
  #224
Somehow my rust bucket puts a smile on my face too.... I hate it for doing that sometimes
Old Mar 22, 2013 | 12:57 PM
  #225
NmexMAX's Avatar
dot dot dot ...
I like this post.
Same with my Pathfinder .... Solid axle this, solid axle that ... meh, I'll have fun with this for now.
Old Mar 24, 2013 | 12:33 PM
  #226
2kMaxim's Avatar
I've been really thinking hard about a Warpspeed Y lately. As the last mod before SAFC tune. Ive listened to a bunch of clips on youtube and there is a definite similar tone that is created from the ypipe. I don't mind this tone....on the cali spec its really only ditching one of the two precats anyway.....how much louder can it really be?
Old Apr 11, 2013 | 05:12 PM
  #227
I would get the stock cat or a high flow one if you're getting a y. With straight pipe when ypu get on it it'll be very loud and stinky. Keep the stock y for emissions purposes ;-)
Ya it doesnt sound as bad as most make t seem but if it can sound z-like with headers and equal y i would be disappointed with anythin else... Unequal y on a maxima makes it sound like an american ohv v6 imo :-P
Old Feb 22, 2015 | 10:38 AM
  #228
2kMaxim's Avatar
I figured sunday was the perfect day for a.....REVIVAL! Lol.
So I now have the coilovers on, the rear wheel spacers and last but not least the YPipe. My setup is warp y pipe > warp test pipe > stainless b pipe > stock calsonic muffler.
I have yet to dyno, as I have to get the pesky $1000 balance off my credit card before I spend another cent!
As far as sound its definitely more aggresive than it was before. We had a small leak between the manifold and the ypipe in the beginning which sounded like hell, but we got that fixed with a chunky lead gasket. I will say this...without a nice chambered muffler such as the factory one, theres no way you can get away with the setup I have. It would sound insanely loud. With the stock muffler its a tad more raspy than the stock y pipe but its not by any means loud. If i eventually want to be **** and do some exhaust sound "tuning" I will probably have a shop weld an inline resonator where my test pipe is...or my b pipe. At WOT it sounds straight up evil. Totally worth it.
Powerwise its absolutely noticable. Mainly from4-6.5k rpms...the needle just flys up way faster. I cant wait to see what it yeilds. Im praying it bumps me up over 200wtrq and nearly 200whp. Id be satisfied.
Mar 12, 2020 12:06 AM
SpeedCrazie
Sep 16, 2016 03:41 PM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
ef9
Sep 10, 2015 10:35 PM
