Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
BlackStone Report: NOT good!
Old Jun 17, 2003 | 05:05 PM
  #81
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Originally posted by iwannabmw
I stand semi-corrected on the thickening. Using Blackstone's numbers it's up slightly. Using Redline's spec sheet, it's right on.
Semi-corrected...sure.
With regards to the 10W-40 acting like a dino 20W-50, viscosity doesn't really have anything to do with this. It's more a function of a better film strength and less resistance to shear. A synthetic oil with a lower viscosity will offer the same protection as a dino oil with a thicker viscosity.
About the filtration: More surface area alone might allow more dirt to enter, but if the filter can trap more dirt and flow more air at the same time, that's a different story. Cosider these results for the cars that I'm responsible for: My 97 Max with a cone filter has Si readings of 7 and 9 for intervals of 8k. My 90 BMW with a cone filter had a Si reading of 5 at the 4300 mile sample. The 97 Altima I care for uses the stock paper filter. It had a Si reading of 6 at the 4400 mile point. Considering the BMW is mostly a track ride and lives at WOT, you'd think it would ingest more air Same mileage interval with a cone filter actually had less dirt than the paper one, and this on an engine that should have considerably more. One last data point is the 01 Legacy with the stock paper filter that had a Si reading of 13 at 5921 miles. I'll take the readings from the Max with the cone and the longer interval any day.
You should check out the 5th gen forum. We(I) have been arguing about that. You should contribute. I even brought up Amsoil's two stage foam filter vs. OEM oiled paper, which I'd like your comments on. Thanks.
Old Jun 17, 2003 | 05:11 PM
  #82
IceY2K1's Avatar
Originally posted by bill99gxe
Ice,
In looking again over your Sentra and Maxima results, I think your 10W/40 viscosity could be causing a decrease in iron and an increase in aluminum and lead, while your silicon must just be your area of the country since your Sentra is consistently coming in at low teens as well.
I'm not sure if that's good or not, but I'm pretty sure those changes are the result of my atypical driving habits. I've been doing lots of HIGH speed hwy travel and then EXTREME short trips with flogging before the car is warmed up. Don't ask why, but I just can't resist.
In addition, did you notice that your Sentra using Valvoline MaxLife had several higher levels of wear metals than the Mobil 1 Drive Clean? Further evidence that Valvoline dino and synthetic oils are some of the poorer performing oils out there.
Yes, Valvoline will NEVER see the inside of ANY of my engines again. I'm VERY impressed with the Mobil Blend and I'm anxious to see if the data is backed up with my next sample. However, it's the new Mobile Blend "Plus", which is supposedly more formulated for high-mileage vehicles. I'm going to stick with the Mobil Blend unless I get a wild hair up for some test mule samples.
Old Jun 17, 2003 | 09:09 PM
  #83
bill99gxe's Avatar
Evil Administrator - "The Problem"
[Loaded Question]
I wonder if anyone has a baseline analysis of the new Drive Blend Plus......
[/Loaded Question]
I've yet to see any specific empirical differences between regular and High Mileage formulas within a brand (e.g. Castrol GTX vs. High Mileage), but some people have reported reduced leaks, etc. by simply switching to a "High Mileage" branded oil. Pennzoil High Mileage immediately comes to mind....
Old Jun 18, 2003 | 12:27 PM
  #84
IceY2K1's Avatar
[Loaded Question]
[/Loaded Question]
I too doubt there is much if any difference between the "regular" and "high-mileage" versions.
I went back to Wal-mart and couldn't find the Drive Clean Blend Plus on the shelves. If they don't carry it, I'll be sticking with the regular Blend.
I would get a baseline, but I'm not using OAI anymore and I doubt the difference would be much. Plus, I've spent enough for now on analysis's. I'm going to keep getting the Maxima analyzed, but unless I decide to investigate air filtration on my test mule, I doubt I'll spend more $$$$ on it.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Adoubi21
Dyno Discussion and Slips
Sep 7, 2015 09:34 AM
