Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Change to synthetic?
Old Aug 16, 2003 | 03:40 PM
apeg's Avatar
I have a 96 max I got it used and it is time for an oil change I am wondering if I should go synthetic?
If I want the car to last as long as I can, will this be a good step to take?
Old Aug 16, 2003 | 05:25 PM
foodmanry's Avatar
Da Roller Coaster!
Yes.
Old Aug 21, 2003 | 10:53 AM
johnny2kgle's Avatar
Since you have an older car, you might want to consider this stuff http://www.auto-rx.com. The other option is to use Amsoil Engine Flush before changing over to synthetic oil. Mobil 1 5w-30 is your best off the shelf choice.
I don't know if you have a 5 speed or auto, but using a synthetic product (gear oil/atf) would also help you extend the life of the entire powertrain.
Old Aug 22, 2003 | 08:45 PM
bukii's Avatar
Switch to synthetic, its MUCH better. You will love it. cleans better and you can go longer between changes.
D
Old Aug 23, 2003 | 08:58 AM
apeg's Avatar
well i did it... i am now running with mobil 1.. cant realy notice much dif in ride. But the peace of mind knowing i will drive another 50000 Miles before the car goes helps me sleep better @ night LOL
Thanx for all your helps guys
Old Aug 27, 2003 | 07:51 AM
largestal's Avatar
good for you. I have changed to synthetic on every piece of machinery I use. Generator, pressure washers, mowers, tractors and go-carts. All of them are running better and the internal parts are MUCH cleaner on the few times I have had to tear anything down.
Old Sep 26, 2003 | 07:21 AM
bigcozz's Avatar
use the synthetic but make sure you stick to b/c once you change you really shoudlnt change back to egular oil.
Old Sep 30, 2003 | 02:43 PM
Y2K2Driver's Avatar
Does this also apply to a transmission? I switched to Redline MT-90 a while ago, but am now considering going back to the OEM stuff since the shifts are notchy. Do you think this will be a problem?
Old Oct 1, 2003 | 07:58 AM
iwannabmw's Avatar
No. It would be no problem for motor oil either.
Old Oct 3, 2003 | 07:46 AM
Y2K2Driver's Avatar
Cool, thanks for the clarification.
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
doctorpullit
Mar 29, 2016 11:08 AM
Noela
Sep 26, 2015 08:22 AM
