Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Synthetic vs Synthetic blend
Old Mar 11, 2004 | 12:06 AM
Nismotic's Avatar
Always sunny in philly
i saw a thread on this but cannot search. What is the best for our beloved Maximas? I've always liked to use full synthetic but its pretty costly. Would synthetic blend do the trick as well? What is the main difference?
(im currently using Mobil 1 synthetic blend)
Also, i've been using the regular pennzoil motor oil (since my gf's uncle owns an auto garage and its been too cold to change it on my own). What are the main differences?
Old Mar 11, 2004 | 08:25 AM
tweeter007's Avatar
I beleive syn-blends are not that that great. One of the main benefits of synthetic is that it maintains it's viscosity when cold(stay's thin and runny) easier starts, oil to top of engine quicker. I worked at a lube shop years ago and a guy brought in his own castrol syn-blend that was in his trunk all night in the winter. It took about 15 minutes for us to empty 4qts into his car, thick like molasses! Stick with 100% syn, it's worth the extra few bucks IMO.
Old Mar 11, 2004 | 04:17 PM
formz
Yea I mean if you think about it you're only spending maybe $10 more every oil change. With my driving, I do oil changes about 3-5 times a year, so it's really not that much savings spread out over the course of a year.
Old Mar 11, 2004 | 05:07 PM
Virus's Avatar
Total waste of money. It won't provide significant extended drain intervals like some full synthetics do so what's the point.
Old Mar 11, 2004 | 05:59 PM
limsandy's Avatar
I say stick with the Mobil1 full synthetic, although I personally use Amsoil full synthetic 5W-30.
~limsandy
Old Mar 11, 2004 | 06:08 PM
iwannabmw's Avatar
If you want the benefits of a synthetic, spend the money and use a good one. If you don't, save your money and use a good dino oil. The blends are way to pricey for the small advantage they MAY have over a good oil like Chevron Supreme or Castrol GTX.
Old Mar 11, 2004 | 08:28 PM
Nismotic's Avatar
i just want to make my car happy. i have 72,000 miles and want to know what would be best for the car
Old Mar 12, 2004 | 12:32 PM
Virus's Avatar
Absolute best would be Amsoil S2k, but unless you take full advantage of the extended drain intervals, it would probably be a waste of money.
Old Mar 12, 2004 | 04:16 PM
NYC TAR's Avatar
The owner manual say not to use Synthetic Blend.
Quote form a 02 owner manual " Do not mix mineral based and syntheric type oils in the engine at the same time". Techinical speaking that is mixing both oil together.
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
pjgreek
Sep 9, 2015 09:30 PM
flu2000
22
Sep 2, 2015 07:29 AM
