Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Changed MT90 after 19,250 miles.
Old Aug 5, 2004 | 01:57 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Could all be in my head, but I'd recommend changing MT90 out every 10-15K at least for HOT climates like mine. Seems much smoother, less clunky/notchy, and easier to engage gears.
Like I said, it could all be in my head, but I pretty much noticed the difference immediately.
Old Aug 6, 2004 | 08:00 AM
SkoorbMax's Avatar
I put some in my 00 at 59k and I'm at 71k now. I have to be honest and tell you that I have no plans of even thinking of changing it for at least another 40k. The damn stuff is freaking expensive!
Old Aug 6, 2004 | 08:20 AM
spirilis's Avatar
I have at least 40K miles on my MT90... starting to feel a little notchy in some gears, especially going into 1st sometimes. I should change it soon.
Old Aug 6, 2004 | 09:12 AM
IceY2K1's Avatar
I'll be going on a road trip up into the mountains this weekend, so I'll really get a chance to row through the gears. However, I've been downshifting a lot to see if it's in my head and so far everything has been smoother then normal. Just sitting at the light going through the gate seems easier and less clunky except 3rd which is fuked from 5th-to-3rd hwy downshifts.
MT90 may be fine for 40K or longer, however I think it definitely thickens up or loses some of its friction modifiers or something by 15K+. At least mine does in this heat.
The difference so far is definitely worth it to me for the $35/1-1.5yrs., but I wonder how long it lasts.
Old Aug 18, 2004 | 03:11 PM
Larrio's Avatar
The Definitive AE Master
my mt-90 is getting loud and i only have 7-8k miles in 8 months
Old Aug 18, 2004 | 03:20 PM
SkoorbMax's Avatar
Damn, guys! As I mentioned in my other thread, Nissan doesn't even have a recommended change interval on the gear oil that comes from the factory (the manual says no word of changing it, and of the four dealerships I called, three said not to bother, and one said 30k, but they are a shifty stealership).
Old Aug 22, 2004 | 06:24 PM
matty's Avatar
Would the Redline MT-90 work on my 92' Nissan pickup 5spd witch is the same engine and tranny as the 240 ??
I would like to change it out and put some synthertic in there
-matt
Old Aug 22, 2004 | 08:43 PM
DAVE Sz's Avatar
Hooooooonda.....
FSM says every 30k miles or 24 months in NORMAL conditions. That's for both auto and 5spd.
Old Aug 27, 2004 | 08:45 PM
IceY2K1's Avatar
I had OEM fluid changed and analyzed with only 15,000 and it did NOT test very well.
I'd change it more often with non-synthetic.
Old Aug 30, 2004 | 09:14 AM
SR20DEN's Avatar
VQ Wizard
I agree with you Icey. The 6 speeds seem to be even worse. The newness of the oil seems to wear off in only a few thousand miles.
http://forums.maxima.org/showthread.php?t=333673
Old Aug 30, 2004 | 01:17 PM
IceY2K1's Avatar
I'd say that's probably due to the 6spds 2.5qt capacity vs. the 5spds 4.5qt capacity.
I think I'm going to try Amsoils' MT fluid next and see how long its friction modifiers last.
Old Aug 30, 2004 | 07:47 PM
iwannabmw's Avatar
Did you have this sample analyzed as well? It would be interesting to compare.
Old Sep 2, 2004 | 10:52 AM
Glude's Avatar
I need to change my tranny oil in my 04 6 speed. Only problem is I dunno how to do it, or how much MT90 I need to order. Ive got 35,000 miles on my 6th gen and put all that on in less than a year. My trans is starting to feel really notchy and when Im in 1st gear I hear a gurgling fluid noise until I shift. Is this the trans doing that? Any help would be appreciated. thanks
Old Sep 2, 2004 | 06:31 PM
Cutler's Avatar
Run some shockproof in them 6 speeds, see how that holds up
Old Sep 2, 2004 | 07:42 PM
SR20DEN's Avatar
VQ Wizard
The 6 speed only requires about 2.5 quarts.
There is a fill plug and a drain plug on the transmission. Simply drain out the old oil and refill with new oil upto the fill hole.
Old Sep 2, 2004 | 07:53 PM
IceY2K1's Avatar
No, I was planning on it, but got rushed and did an oil change and MT90 change the day before leaving town and I spaced it. Hopefully, I'll get this sample and then I'm going with Amsoil.
I wouldn't mind throwing in something thicker sacrificing a bit of horsepower just so it doesn't get notchy and can handle the abuse.
03VQMAX
Nov 10, 2015 03:39 PM
markevans999
Oct 25, 2015 08:27 AM
JoshG
51
Sep 21, 2015 10:41 PM
pears
Sep 18, 2015 05:25 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
