Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
how do i disconnect the abs actuator in 1998 max?
Old May 2, 2005 | 08:03 AM
ne max's Avatar
I want to bleed the brake fluid on my max and the Haynes manual says to first "disconnect the 4 electrical connectors to the ABS actuator" I looked up the diagram but it shows 4 connectors only for 1995-96 models, and i cannot find a diagram for a 1997-99 model. I looked near the actuator and found 2 bundles of wires coming out of it, leading to only 2 "snap-type" connectors nearby the actuator on the right side of the engine compartment (vs. on the left side in 1995-96 models). Are these the only 2 connectors i need to disconnect for the ABS actuator? Thanks for any help you can provide.
Old May 2, 2005 | 08:10 AM
nick's Avatar
disconnect the battery , than go ahead with brake bleeding , just make sure you don't push the brake pedal all the way to to floor ( by doing that you could damage Master Cylinder)
Nick.
litch
123
Jan 4, 2024 07:01 PM
bbsitum
Sep 6, 2019 07:31 PM
ajahearn
Sep 19, 2015 03:03 PM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
