Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
too late to use synthetic motor oil?
Old May 27, 2005 | 01:58 PM
Jonny98max's Avatar
i have 100k on my 98 SE......i have been reading about how much better synthetic protects ur engine then normal motor oil?
i dont see any oil leaks coming from my engine.....if so not anything dramatic....i was just wondering if it would help to switch to synthetic motor oil instead of using the regular stuff?
is it worth the $?
Old May 27, 2005 | 02:01 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
well you can run a higher intervalts with Synthetic oil as suppose to regular oil.
I change mine every 5000 mile. I don't have a turbo or supercharger. I think for you it might be too late with that much mileage.
Old May 27, 2005 | 02:30 PM
4x4Max's Avatar
how bout with 69k?
Old May 27, 2005 | 02:36 PM
sterlingmaxima's Avatar
all you need to do is get some motor flush then after running that use synthetic you be fine bro.
Old May 27, 2005 | 02:39 PM
southeast_first's Avatar
it's never TOO LATE per se, but you very well could discover leaks when you switch to syn. it doesn't mean synthetic is bad for your car (actually, it's the opposite), it just means there are problems you need to fix.
check the fluids forum for more info, but imo you should both think about switching.
edit: heh, this actually was moved WHILE i was posting...
Old May 27, 2005 | 04:35 PM
shurik's Avatar
Originally Posted by 4x4Max
how bout with 69k?
Well I started to use mine when my car had 49K, and it's still good. Maybe that would help.
Old May 27, 2005 | 05:16 PM
Bobo's Avatar
I saw a post a number of months ago that suggested not even starting to use synthetic for a 4th Gen until 70K. The individual making the post seemed to know what he was talking about and I took note of what he said in my data base, being as I take note of everything, lol.
I have 58,400 mostly highway miles on my 95SE and I think I will switch to Mobil 1 in about 2K when I'm due for my next oil change.
Old May 27, 2005 | 07:19 PM
kcryan's Avatar
its never too late, theres a guy who changed with 195k and had no leaks.
Old May 27, 2005 | 09:53 PM
wannaboostbad's Avatar
yeah, i started using it last oil change at 81K miles. Havent had time to fully in-depth look for leaks yet.
Old May 30, 2005 | 08:46 AM
NOCturnalI30's Avatar
I just switched to synthetic and i didnt flush out the motor or anything should i have???
Old May 31, 2005 | 07:50 PM
no, you don't need to.
Old May 31, 2005 | 09:19 PM
brashncurn's Avatar
Ok, Well I just switched to syn at 275K in my 89 maxima and it runs great. no flushing, leaks or anything. I dont even think I changed my oil filter, OK so I did, but thats not the point is it.
Old Jun 1, 2005 | 05:03 AM
rays01se's Avatar
Do the swap. As mentioned earlier, it's never too late. If the max has high miles when you do the switch, just check for leaks. If it leaks, replace the gasket(s). Done...............
Old Jun 14, 2005 | 10:37 AM
dr-rjp's Avatar
Do the swap..but do it gradually by following this recommended procedure:
After the first 1,000 miles, change the filter. Add a new filter filled with synthetic.
After the next 2,000 miles, change the filter again like before.
Make your next change at 5k, both oil and filter.
From that point onwards, you can go 6-10K between changes.
The reason you change filters often in the beginning is that the synthetic flushes out a lot of gunk left over from the previous oil, and into the filter.
Old Jun 14, 2005 | 10:45 AM
Jeff92se's Avatar
I'm needing a caw
Can you give me some links that actually proves synthetics has any more detergents than normal dino oil?? I'd like to read those thanks.
Old Jun 14, 2005 | 11:01 AM
jaedaliu's Avatar
yay! someone posted my question so I didn't have to wait 3 weeks for me to get 15 meaningful posts so I could ask my question.
I just hit 100k last week, 98 (gxe though) just like the original poster.
Aparently the consensus is that it's never too late to change to synthetic.
question: should I use the OEM nissan filter when I switch to synthetic? lately I've just been using the first cheap thing I could find because I've been hitting 3k miles every 5 weeks.
question2: How can I tell if there are leaks? dark spots under my car from parking overnight and in the lot at work?
Old Jun 14, 2005 | 12:13 PM
Bobo's Avatar
Don't use crappy filters. The consensus is Nissan OEM filter, or Mobil 1. Look for fresh spots on the pavement/floor.
spencerwh1
Jun 30, 2016 05:44 AM
fastcarny
Oct 12, 2015 07:06 AM
pears
Sep 18, 2015 05:25 AM
97_GXE
20
Sep 17, 2015 08:12 PM
asianstyle
Sep 10, 2015 11:30 AM
