oil change ... please help me (97 max)
I am trying to remove the drain plug (ofcourse first time oil chnage) by using
14mm wrench, but it's not loosen at all, even i use lot of force. I am trying to loosen the plug in the clock wise direction.
am i doing something wrong.....please help me.
Good advice above. Counter Clockwise with a breaker bar works best. Also tapping with a rubber mallet to "break lose" the nut helps. You certainly don't want to round off the edges of the plug, so make certain you have a tight fit.
MatthewsMaxima
09-11-2015 03:21 AM
