Oil consumption or not being level during change?
When I change my oil, I drive my car on little ramps that are about a foot high so I can get under the car. On my last oil change(filter), I got back 3.5qts. Last time I changed my oil, I only got about 3qts back, but I went an extra 2k miles on it. I use mobil 1 synthetic 5w-30. I'm at 48k and this oil change was after 3k. This is how the car looks when I change oil and filter. I would think that this way is better than the car being flat because the oil is all going to the part of the pan where the drain plug is. Thanks...
this is how I change my oil too...I jack up the car as high as I can then put it on stands....this allows the drain plug to sit at an angle....
try this next time...instead of draining out the oil and measuring it...just read the level on your dipstick every MORNING before you leave for work...I know its about 1qt from the LOW mark to the HIGH mark....if you notice your car is consuming oil, the dip stick will read either between the low & high...or lower than the low....that is a good indication your engine is consuming oil....
Stupid question, I have the jackstands as well. Where exactly do you place them? I cant use them as I do not have one of those hand hydraulic jacks and the one in the trunk...i can't get it high enough to slide the jackstand underneath the car.
Maxima.org Sponsor and Donating Maxima.org Member
On the rear, you can place the jack in the center of the axle and then position the stands on either side of the jack...
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
