Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
View Poll Results: OIL?
MOBIL 1
155
61.02%
SYNTHETIC
58
22.83%
OTHER
41
16.14%
Voters: 254. You may not vote on this poll
Do you use Mobil 1?
Old Jan 22, 2007 | 02:01 PM
  #81
SilverMax_04's Avatar
Originally Posted by Trilitai
I'm starting to use mobile 1.
Mobile is a town on the Gulf Coast of Alabama.
Mobil is part of the large oil company Exxon-Mobil. The two (Mobile and Mobil) are not the same.
Old Jan 31, 2007 | 08:25 AM
  #82
PSSmith's Avatar
I used to use the 5/30 Mobil 1 until I switched to the extended formula last year. I have 3 vehciles (95 Chevy truck, 2003 Forester, 92 maxima). I run the extended Mobil 1 in all three and change it every 7,000 miles. The Maxima now has 235,000 miles on it, no leaks, no burning. It gets red lined occasionally and spends many days at 85 plus mph. World's best engine! I also run Mobil 10/30 in the tranny (5 speed).
Only other car, a 1951 MGTD gets 20/50 valvoline.
Old Jan 31, 2007 | 12:37 PM
  #83
d00df00d's Avatar
Old enuf to pick his own gears
10bits
Old Jan 31, 2007 | 12:38 PM
  #84
d00df00d's Avatar
Um. Engine oil in the transmission? Doesn't that transmission call for some kind of MTF or gear lube?
Old Jan 31, 2007 | 12:51 PM
  #85
PSSmith's Avatar
Gear lube
At about 120,000 miles, the transmission began shifting a bit stiff after running it at freeway speeds. I asked the service tech at Nissan what they recommended. Since here in Maine we get sub zero temps in the winter for weeks at a time (in spite of globabl warming!), he suggested the synthetic engine oil. Many of the mechanics at the dealership also ran synthetic (Mobil 1). I tried it, and I have had great success. I don't baby the car, and it shifts with two fingers. I change the oil every 30,000 miles. It's been over 110,000 miles since I began using the Mobil 1.
I had a Dodge Colt Vista back in the late 80's. I had a transmission oil change and the service tech put in 90 wt oil. The transmission lasted about 6 months.
My 92 Maxima is still going stong on the original clutch and transmission. In my Subaru, I was going to put in Mobil 1, but the service tech explained that the Subaru spec oil was a synthetic blend and I should stick with it which I have.
In the 51 MG, I use a 90 wt synthetic in the transmission and rear end. It made a big difference in this old classic.
It works!
Thanks for the feed back.
Old Feb 6, 2007 | 08:21 PM
  #86
NismoFrk's Avatar
considering that most auto manufacturers use Mobile 1 (nissan, Chevy (Vette) etc), and that they are the first company (I believe) that came out with a synthetic - I wouldn't go with anything less.
Old Feb 7, 2007 | 05:09 AM
  #87
maxima0001
I used Royal Purple 5w/30 in the winter...
and Royal Purple 10w/30 in the summer
Old Feb 7, 2007 | 08:25 AM
  #88
d00df00d's Avatar
Amsoil was the first with an API-rated synthetic.
Old Feb 7, 2007 | 09:18 PM
  #89
maxima02r34's Avatar
i live in miami and i put mobil1 syn. 10w-30 thats. because my car has more than 100000 miles
Old Feb 10, 2007 | 05:55 PM
  #90
Geoff's Avatar
mobil 1 5w-30. oil is clean at every change; used since new, 188k miles
Old Feb 20, 2007 | 06:14 AM
  #91
Jason_03_Max's Avatar
mobil 1 5w30 every 5k miles
Old Feb 25, 2007 | 08:38 AM
  #92
Nismo_maxima97's Avatar
mobil 1 is good but Royal Purple is a lot better
Old Feb 25, 2007 | 08:59 AM
  #93
nismology's Avatar
According to.............?
Old Feb 25, 2007 | 09:05 AM
  #94
d00df00d's Avatar
...people who race their cars, change their oil at 2,000 mile intervals, and think everyone else does the same.
Old Mar 10, 2007 | 06:20 PM
  #95
maximan57's Avatar
I've tried many oils and filters in my '99(including Mobil 1). I think it's best with Castrol Synthetic 0w30 European Formula and the Napa Gold filter.
I am using the Mobil 1 synthetic ATF.
Old Mar 10, 2007 | 08:46 PM
  #96
andrei3333's Avatar
Castrol GTX is the best regular oil ever made, PERIOD.
Old Mar 11, 2007 | 06:08 AM
  #97
JwaxMax99's Avatar
OK, please expand on this statement.
Old Mar 11, 2007 | 09:29 AM
  #98
STARR's Avatar
From what I have read on the oil Forum, Castrol GTX has been shown to go 8000 miles for just a dino/regular oil where other oils are done at 3-5k
Old Mar 11, 2007 | 10:36 AM
  #99
andrei3333's Avatar
I dumo it just smells so good, haha jokes, no it seems to protect better then penzoil (my experience) and its way better then some no name brand oils that i have used in other cars
Old Mar 11, 2007 | 12:22 PM
  #100
All you have to do is look in the stickies above to see that GTX produces better results when it is tested after use. It's all in the stickies.
Old Apr 2, 2007 | 08:49 AM
  #101
plaman88's Avatar
Mobil 1 5w-30 , do you Max guys run 10w-30?
Old Apr 6, 2007 | 08:21 AM
  #102
d00df00d's Avatar
There's no real reason to run 10w-30 if you're using high quality synthetics. 5w-30 and 0w-30 do just as well (or better) at operating temperature and flow better when cold.
Old Apr 6, 2007 | 08:26 AM
  #103
yehudi's Avatar
whateveer they have at the lubejoint
Old Apr 11, 2007 | 09:47 PM
  #104
playboi21617's Avatar
I havent changed my oil before on my car i usually have the dealership do it but i ran out of free coupons from when i bought it so iam going to start to doing it myself so my question is where is the oil filter is at the bottom or on the top so where in the middle.
Old Apr 14, 2007 | 07:01 AM
  #105
In the 6th Gen Max, the filter is located behind the right front wheel well cover. Just lift up the cover and the filter is mounted horrizontally with the "bottom" of the filter facing the right side of the car. The 2002 may be different.
Old Apr 14, 2007 | 07:06 AM
  #106
nismology's Avatar
Same engine. Same place.
Old Apr 16, 2007 | 08:48 AM
  #107
cflemm's Avatar
Mobil 1 synth every 7.5k here (mostly highway miles)
Old May 8, 2007 | 01:55 AM
  #108
ericblackburn's Avatar
Question, well really I'm confused. All of you say mobile is in the car from the factory, if this is the case then why does the owners manual and my dealership say the recomeded oil is Castrol GTX 5w30?
Old May 8, 2007 | 02:13 AM
  #109
All of us have not said that. It has been reported that Corvettes come from the factory with Mobil 1, but certainly not a Max. That is why Castrol GTX is recommended until your Max is fully broken in -- at about 10 K miles. Then you can switch to fully synthetic motor oil.
Old May 8, 2007 | 05:16 AM
  #110
Love_00_Max's Avatar
Mobil 1 line of products are top grade but I can get Pennzoil Platinum for $3.99/Q, I wouldn't spend another dollar/Q for Mobil1.
On BITOG, the UOA on PP on different vehicles has been outstanding and I use it on my other vehicle. Since my Max needs a SL formula, I am on Pennzoil HM oil.
Old Aug 7, 2007 | 11:51 AM
  #111
hybridc24k's Avatar
So i was strolling through Walmart cuz there was nothing else to do while we were waiting to kill time before the movie started and noticed Mobile 1 full synthetic for $19.99 for 5 quart bottle. I ended up buying 5 of those. LOL.
Old Aug 15, 2007 | 05:08 PM
  #112
jteer1971's Avatar
I use the synthetic but am thinking of switching to Royal Purple...for filter, anything BUT Fram
Old Sep 2, 2007 | 09:14 AM
  #113
RacerX1320's Avatar
If a car is a daily driver 90% of the time <like mine> i think just about any oil at 3k intervals will protect your baby. I used to run mobil 1 in my S2000 because thats what the manuel called for.
My 00 max calls for Castrol gtx 5-30 weight, i look at it like, if the manuel calls for it why not use it. Not to mention Castrol is made in Germany, and we know how those German Engineers get down.
Side Note: Many bmws run Castrol from the factory.
Old Sep 2, 2007 | 10:06 AM
  #114
d00df00d's Avatar
Castrol is a German company, but virtually all of the Castrol products sold in the USA are made here.
All BMWs run Castrol from the factory (although definitely not GTX).
Castrol GTX 5w-30 is a great oil for all but the hardest-driven Maximas. It should have no problem with 5k mile intervals.
Old Sep 2, 2007 | 11:11 AM
  #115
Castrol is a lubrication company that has been owned by BP for about 4 years or so. I think it was a British company even before it was bought by BP -- which, at least for now, keeps it a British company.
Castrol has lube plants around the world. There is some Castrol synthetic motor oil that says on the label that it was made in Germany -- the rest could be made in any of their plants -- unless the label specifically says otherwise.
Old Sep 2, 2007 | 01:05 PM
  #116
d00df00d's Avatar
Ack. I stand corrected on that. :
Old Sep 2, 2007 | 01:11 PM
  #117
You are right about GTX being good for 5 K mile intervals. It's the best widely available dino oil out there, IMHO.
2kmaximel
Nov 29, 2015 01:51 AM
f.matejaiii
Sep 21, 2015 12:09 PM
98nismomax
Sep 14, 2015 09:25 AM
ag90fox
Sep 9, 2015 12:22 PM
98nismomax
Aug 13, 2015 12:44 PM
