Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
how much seafoam
Old Apr 23, 2006 | 04:47 PM
maximaownsyou's Avatar
how much seafoam
how much seafoam did you guys use for one application
Old Apr 23, 2006 | 04:50 PM
NYC32798's Avatar
Everyone says to use 1/3 to 1/2 a can but I used more on my car since it has 208,000 miles on it and I doubt its ever been cleaned.
Old Apr 23, 2006 | 04:59 PM
steven88's Avatar
Need A Light?
your suppose to use 1/3th through the brake booster....1/3th through the gas tank....and 1/3th through the crankcase...
Old Apr 23, 2006 | 09:22 PM
Bobo's Avatar
Although I have never used Seafoam, I understand there are better products to use through the crankcase and gas tank. When the time comes I may use it through the brake booster, but at 63K mostly highway miles, I'm not about to use it just yet.
Old Apr 23, 2006 | 09:34 PM
steven88's Avatar
Need A Light?
I agree with Bobo...I would run chevron with techron concentrate through the gas tank....I would use auto-rx for the crankcase....and seafoam through the brake booster.....
It doesn't hurt to use seafoam for all 3 applications though....it's just I prefer chevron thru the gas tank becuz it was specifically designed for cleaning the fuel injection system...
Old May 8, 2006 | 03:15 PM
Supreme Allah's Avatar
I don't wanna start another thread on this so I'd ask here - does engine temp make a difference for Seafoaming? I'm doing it on Thursday so what I was planning, was seafoaming, then going for a drive and hopefully smoke up the town, and then coming back and doing an oil change. Soo... is it ok to seafoam a cold engine?
Old May 8, 2006 | 09:21 PM
00MaxSE's Avatar
Pointy Elbows
I bought a can too. I need to do this soon.
Old May 10, 2006 | 07:28 PM
CRiME's Avatar
oem ftw!
is it recommended to use seafoam before, or after an oil change? or does it not matter at all? just wanted to make sure. thanks
Old May 10, 2006 | 08:06 PM
steven88's Avatar
Need A Light?
before an oil change for sure
Old May 10, 2006 | 10:00 PM
CRiME's Avatar
oem ftw!
thanx much. i just put in some mobil1 synth, and was considering a seafoam treatment via the brake booster line. i'd hate to have to change the oil again so soon.
Old May 10, 2006 | 10:27 PM
NYC32798's Avatar
You are supposed to let it warm up to operating temperature before adding the sea foam. When I got the fuel system treatment done at valvoline, they told me the car had to be at operating temperature and i'm guessing sea foam is similar to the stuff they used only I think sea foam works better.
Old May 11, 2006 | 11:10 PM
whatsthegoodwor's Avatar
Definitely at operating temp, and before an oil change. Be careful not to let it suck in too fast, any more than a dribbling faucent or you mightl hyrdolock your engine.
220k+ A32
Sep 23, 2015 03:38 PM
MrEous
41
Dec 5, 2005 03:50 PM
E55AMG2
50
Dec 21, 2004 09:15 PM
MrGone
58
May 25, 2004 11:57 AM
