Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Big problem after MT oil change
Old Jun 12, 2006 | 05:26 PM
white97gxe's Avatar
I just recieved my 5 quarts of amoil manual transmission oil and went to change it. I use the shift sensor to drain instead of the plug. Everything went smoothly until i was refilling. I noticed a little leak and i tightened the bolt for the sensor a tighter. I think i over torqued it because the gasket that holds the sensor in place just broke. Now i have 5 quarts of brand new tranny oil leaking, about 1 drop every 30 seconds. Anyone know a solution to this without wasting the oil? Ive put a oil pan under the leak until the dealership opens tomorrow so i can purcahse a new gasket. I figure i drain out he new oil into the pan and send it through a coffee filter incase anything got into the pan over night. Is this a bad idea?
Old Jun 12, 2006 | 10:25 PM
SilverMax_04's Avatar
Sounds reasonable to me.
Shows the need to use a torque wrench when doing jobs like this. You should also properly torque your wheels when you (or a shop) removes them for any reason.
Old Jun 13, 2006 | 05:11 AM
DAVE Sz's Avatar
Hooooooonda.....
next time you'll use the plug like you're supposed to. I did my friend's max maybe a year back, his sensor had the tab that the bolt goes through broken off so whoever did it before used a washer to hold it in place.
kmitchel
Oct 30, 2016 05:28 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
tnewbs
Aug 28, 2015 10:15 AM
maxinout93
Aug 20, 2015 02:17 AM
