Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Brake fluid question, contaminated or not?
Old Jun 26, 2006 | 04:54 AM
steven88's Avatar
Need A Light?
So I recently did a brake job on my car...I sent the rotors off to pepboys (to get resurfaced) and came back home and waited...while that was happening, I decided to prep my pads by adding anti squeal gel on the shims...and pushing the piston back in with a C-clamp...problem is, when I pushed the piston back in, the brake fluid overfilled.... so I took the cap off caught it with a few towels...
Now the thing is, I forgot to put the cap back on...and I went back inside the house...then a few hours later, I drove off to pepboys to pick up my rotors and AFTER I reassembled everything, is when I found out the cap on the brake master cylinder was still off....is this bad?
The fluid has been recently flushed (i'd say 8 months old) and the cap was off for 3-4hrs I'd say....will my boiling point be bad? I don't drive too hard...mostly city driving and nothing too crazy...
Old Jun 26, 2006 | 07:24 AM
CCS2k1Max's Avatar
If you want to play it safe, remove the fluid from the reservoir with the old baster trick and refill it with fresh fluid. I doubt moisture has difused into the lines yet.
Old Jun 26, 2006 | 09:26 AM
steven88's Avatar
Need A Light?
NIce! Thats all I really needed to know...
sctludwig
Sep 1, 2022 01:32 PM
BkGreen97
Apr 2, 2016 05:47 AM
dcardello
Sep 3, 2015 11:44 PM
crazyespn
Sep 3, 2015 01:30 PM
Johnny9595
Sep 3, 2015 05:18 AM
