Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
View Poll Results: Do you fill up the oil filter?
Yes
42
39.25%
No
65
60.75%
Voters: 107. You may not vote on this poll
Filling Oil Filter Before Putting It On?
Old Nov 29, 2007 | 11:34 AM
  #81
pbn85's Avatar
doodfood pretty much gave me the answer I was looking for...
another concern...suppose you do fill up the filter when doing an oil change. The amount of oil is so minimal (inside the filter) that I would be surprised if it could provide enough lubrication for the engine until the oil in the sump started to circulate
Old Nov 29, 2007 | 11:39 AM
  #82
Jeff92se's Avatar
I'm needing a caw
Considering many techs/mechanics agree that much of the engine wear occurs at startup, I'm not sure why one would purposely handicap the engine by installing a totally dry filter. Some people enjoy ice skating uphill I suppose.
Old Nov 29, 2007 | 01:13 PM
  #83
d00df00d's Avatar
Old enuf to pick his own gears
The important thing is not the volume of oil, it's the time required to fill the filter.
If you put the filter on without filling it, the oil being pumped through the engine has to fill the filter before it can start moving on to other parts of the engine. That can take a few seconds, again depending on the temperature and the oil, and during that time your engine is not getting oil. But, when you fill the filter before putting it on, you reduce or eliminate that time: since the filter is already full when you start the car, the oil doesn't waste any time going where it needs to go.
Imagine holding a cup of water under a faucet and trying to fill the sink: the faucet represents your oil pump, the cup is your filter, the sink is your engine, and the water from the faucet is your oil. If the cup is empty, the first few seconds' worth of water flow will have to fill the cup before water starts falling into the sink. If you fill the cup beforehand, there is no delay: any water that goes into the cup immediately overflows into the sink, as though the cup were never there.
Old Nov 29, 2007 | 01:14 PM
  #84
Jeff92se's Avatar
I'm needing a caw
^^ exactly.
Old Dec 12, 2007 | 10:40 PM
  #85
RW-Maxima's Avatar
Sure. If I can. I understand not doing it if it will all spill out anyway, but why wouldn't you otherwise?
Old Dec 13, 2007 | 07:20 AM
  #86
Colonel's Avatar
Old Fuddy Duddy
Is this english?
Old Dec 13, 2007 | 10:28 AM
  #87
d00df00d's Avatar
Originally Posted by Colonel
Is this english?
Yes. Can you not read it?
Old Dec 13, 2007 | 10:35 AM
  #88
Colonel's Avatar
Old Fuddy Duddy
Guess not...
Old Dec 13, 2007 | 10:48 AM
  #89
Jeff92se's Avatar
I'm needing a caw
It doesn't spill as explained earlier
Old Dec 13, 2007 | 11:05 PM
  #90
SilverMax_04's Avatar
So long as you don't completely fill the filter with new oil -- and you spin it onto the engine fairly fast -- it does not spill motor oil. I was doubtful of this, but found it was the case when I did it the first time. I will now do this at every filter change.
Old Dec 14, 2007 | 08:22 AM
  #91
mfewtrail's Avatar
I fill oil filters on every car that I feasibly can. If the oil filter is placed where I can't fill it without it spilling everywhere, I only partially fill it.
Old Dec 14, 2007 | 01:09 PM
  #92
ROCKART's Avatar
wants an I35
i dont really see the point in making that mess and possibly wasting some oil when you can just install the filter empty and let the new oil seep in there before starting your car. are some of you saying that pouring new oil in the head wont force itself down into the filter until you start the car?
Old Dec 14, 2007 | 01:14 PM
  #93
Jeff92se's Avatar
I'm needing a caw
1) doesn't make a mess if you have read pages 1) - 3) of this thread
2) Pouring oil in the engine does NOT force anything into the filter. It drains directly into the oil pan
Old Dec 14, 2007 | 01:34 PM
  #94
Exactly. Until the engine starts and the oil pump starts working, there is no oil forced through the oil filter (or anywhere else in the engine). And it should also be noted that no oil will seep into the oil filter, either. The filter sits higher than the oil in the pan, so gravity will not cause it to flow through the filter -- only the oil pump -- or the person installing the filter pouring oil into the filter before installation.
Before knocking this practice, try it once. I was doubtful, until I did so.
Old Dec 14, 2007 | 01:39 PM
  #95
ROCKART's Avatar
wants an I35
learn something new everyday....
Old Dec 14, 2007 | 03:24 PM
  #96
That is this site's greatest benefit. Learning "best practices" from others who care about their ride.
Old Dec 15, 2007 | 06:37 PM
  #97
RW-Maxima's Avatar
Is this english?
Really? OK, I'll explain fully and in detail.
The thread is entitled "Filling Oil Filter Before Putting It On?"
My response to that question: "Sure. If I can."
Additional commentary to my succinct response: I can understand how one might skip this step if the filter position is such that the oil would spill out of the filter, but otherwise why *wouldn't* someone want to do this (not just on a Maxima, but on any car)? In other words, I don't see why someone would consciously decide that prefilling the filter would be a bad idea.
How's your English?
Old Dec 15, 2007 | 06:55 PM
  #98
96blackmaxSE's Avatar
boost me.....
How's your English?
STFU....GTFO>>>>
Old Dec 15, 2007 | 09:51 PM
  #99
Delvin's Avatar
The oil pump fills up the filter so fast that it doesn't matter. I've accidentally left my filter off once (out of the 3.5 million other oil changes i did on customers car i leave my own filter off) when rushing to do an oil change and had the car running for like 5 seconds with the filter off the car and lost about 2qts of oil. If you guys are thinking that starving an engine of oil for all of tenth of a second is going to kill your engine you got to be kidding me. Unfortunately I've seen cars run for minutes with NO OIL in them.
Old Dec 16, 2007 | 09:52 AM
  #100
Jeff92se's Avatar
I'm needing a caw
If you think that engine didn't just experience a ton of wear, you're nuts
Old Dec 16, 2007 | 12:30 PM
  #101
Delvin's Avatar
I'm not saying that at all. The car already had 200K+ miles on it and the customer happened to be a courier (No it wasn't SuperChris!!) and the transmission failed about 60K later not the engine. All I'm saying is that the oil filter fills up under normal running conditions in less than half a second. Starting a Maxima with no oil in the filter causes as much wear on the engine as it starting up cold after sitting overnight with a full filter.
Old Dec 16, 2007 | 12:40 PM
  #102
I agree ! Which is why you don't want to race the engine right after starting it up cold after it sat overnight.
But I will continue to partially fill the new filters -- anything to increase the life of this engine, even if it is only minor.
Old Dec 16, 2007 | 02:47 PM
  #103
00MaxSE's Avatar
Pointy Elbows
Old Dec 17, 2007 | 08:29 AM
  #104
Colonel's Avatar
Old Fuddy Duddy
Originally Posted by 96blackmaxSE
STFU....GTFO>>>>
LOL!
Old Dec 17, 2007 | 08:53 AM
  #105
Jeff92se's Avatar
I'm needing a caw
If you're not saying it didn't do quite a bit of damage then I don't quite see how that supports your case.
I think the important diff inbetween starting your car in the morning vs new filter w/ no oil is the anti-drainback valve. Also, at least in the case of my VE30DE, the filter is upright. So even if the oil seeps past the anti-drainback valve, it couldn't drain out of the filter as it's upright.
Even if the filter is sideways, there would be more oil in the filter after you turn off the engine/restart vs a bone dry new filter.
Do what you wish, I'm just saying your logic isn't quite correct IMHO
Old Dec 17, 2007 | 09:06 AM
  #106
d00df00d's Avatar
Exactly. This isn't about saving an engine from instant destruction. It's just a small step that there's no reason not to take because it involves practically no effort.
Old Jan 6, 2008 | 06:10 PM
  #107
nismowolfe's Avatar
I think its a good idea but like others said it really should matter much if the filter is horizontal than its just going to make a big mess.
Old Jan 11, 2008 | 01:06 PM
  #108
BluFlame's Avatar
this is why i change my own oil
Old Jan 13, 2008 | 10:12 PM
  #109
SKarpenz's Avatar
Always start with an oiled filter if possible.
kjlouis
Oct 3, 2015 05:29 AM
homeyclaus
Sep 3, 2015 06:15 PM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
coasterswim
Sep 2, 2015 07:43 AM
