Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
How to change power steering fluid?
Old Nov 5, 2010 | 06:20 PM
rohanmax14's Avatar
Can anybody tell me how to change the power steering fuild.
Drain from top n put new fuild with rp max ATF or royal purple max EZ power steering fuild or do FLUSH?
Old Nov 6, 2010 | 08:03 AM
Kevlo911's Avatar
Kevlo for President
I used a turkey baster and got all the fluid out one time. Takes a while.
Other time I used a vacuum and sucked out all the fluid in the tank. Filled it up, turned the car on and turned the wheel left to right like 20 times and then repeated the process until i used up 1qt of ATF.
Old Nov 6, 2010 | 07:31 PM
rohanmax14's Avatar
so I can stuck it out n put 1 qt of rp max ATF correct n u sure is take a 1 qt? Wbt the fuild left over?
This is my 1st time so I don't want to mess it up.
Old Nov 6, 2010 | 08:08 PM
SuperMario's Avatar
What PS fluid is good? Any good synthetics for the 6th Gen out there? If so where can I find it?
Old Nov 7, 2010 | 06:47 AM
Kevlo911's Avatar
Kevlo for President
Our cars use ATF for the PS fluid.
You won't fill up 1qt the first time, remember, you just suck out the atf in the reservoir and then refill it. then you turn the wheel left to right all the way many many times. then you drain and fill again until you have finished your 1qt of atf.
Old Nov 27, 2010 | 08:36 PM
rond310's Avatar
i just used a siphon tool to get the fluid out of the resevior and did that a few times since you don't get a whole lot out. I figure after 4 or 5 times over the course of a week I should have most of t hefluid changed.
Old Dec 11, 2010 | 10:47 PM
wirelessdude04's Avatar
Yea, i just used a syringe and took old fluid out and put new in. Took quite a bit of time but happy with it. Gotta do this again though
Old Dec 15, 2010 | 02:37 PM
jholley's Avatar
http://www.motorvate.ca/node/49
Old Dec 23, 2010 | 10:55 AM
Love_00_Max's Avatar
Purging the PS of old fluid is real simple. This is what I do every 30K miles and never had a PS issue, no leaks, no pump/rack failures no nothing.
1) Drain the reservoir and unplug the return line connected to the reservoir and point the return line (smaller of the lines connected to reservoir, it’s mostly a 3/8") to a empty gallon jug.
2) Raise the front of the vehicle, set the ignition key in ACC to power the pump but not make it run and then turn the steering wheel left and right all the way each end multiple times till no fluid comes off the return line.
3) Reconnect the return line and fill the reservoir with fresh fluid and do steering locks turning the steering wheel left and right many times till no additional fluid needs to be added to the reservoir. With the reservoir with fluid start engine and have the pump flush out all air from the system while doing steering locks left and right 5 times to purge air of the system. Top it off, lower the front end and you are done.
Old Dec 23, 2010 | 07:05 PM
dragonle87's Avatar
That's how I did on mine. Though a lot of time consuming when you're doing it yourself.
Andy29
Aug 31, 2015 01:59 PM
hydriplex
Aug 28, 2015 02:13 PM
Maxgig
Aug 18, 2015 09:17 PM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
