Bottle Heater Install
Old Jul 11, 2002 | 07:06 PM
Ramius83
How did you guys "attach" the thermostat to the bottle. It says to just put them under the straps that hold the heater to the bottle. Is this all you do? And how far apart do they have to be? Thanks guys.
Old Jul 11, 2002 | 07:19 PM
Jime's Avatar
Re: Bottle Heater Install
Erik mine works off of pressure not heat. It has a pressure transducer that interupts the ground of the heater when the pressure reaches 1050 and connects again at 1000.
Old Jul 11, 2002 | 07:35 PM
//M5'ver
put the thermostat under the velcro straps that are not covered by the heater wrap.. and pull it tight.. i get paranoid and pull over from time to time afer having it on just to make sure it hasnt' fallen off.. but i got used to it
Old Jul 11, 2002 | 08:41 PM
Ramius83
Ok, I wired everything up and everything looks fine. However, without using a mutlimeter, how can I see if my heater is working? I put my hands on the "heater" and I really cannot feel anything. Any ideas guys? I have tried putting a multimeter on the leads going in and out of the actual heater, but I get nothing. It is kinda warm outside, is this the case? Thanks guys......
Old Jul 11, 2002 | 08:43 PM
//M5'ver
it gets hot real fast.. check yoru grounds and wiring.. when i first hoooked mine up it wasn't working right.. and i went over everytihgn again.. and it was fine.. that little orange pad heats up quick
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
220k+ A32
Sep 23, 2015 03:38 PM
RWCreative
Sep 21, 2015 11:01 AM
2kmaximel
Sep 16, 2015 03:19 PM
