Broke off screw in engine, lil help
Question for you guys, a 6mm bolt broke off when I was tightening it down in the engine, outside of course, valve cover area. Weak bolt, snapped the milisecond I turned it with the wrench. Anyway, I can't plier it out as it's flush with the top of the hole. How should I get it out and still preserve use of that screw hole? Tap and die? I don't want to f anything up. It's not essential or anything, but I'm not too high on warping anything. Thanks
Re: Broke off screw in engine, lil help
Make sure you make the hole as cloce to the center as you can. You can use a punch or another sharp object to mark where you want to drill. It will also help to keep the dril bit in place. You also need to drill the hole deep enough. A few months ago I was taking out a broken bolt with an easy-out and I broke another piece of the bolt. Take your time.
Yuri
Yuri
I hope you didn't use locktite. I broke off a M6 bolt on my timimg cover a couple of weeks a go. I used easy outs, reverse tapping screws, and nothing worked.
Also, when drilling, the sides of the hole are softer than that bolt. If you drift off while driling, it can lead to more trouble. And yes, I'm speaking from first had experience.
I restore old rifles. If you stuble across a bolt that has loctite, apply heat! You can use a solder gun (precision) or a small butane torch to heat up the bolt. This will turn the loctite to powder and voila!
Karguy's recommendation was right on the money. Just be careful not to break off your easy-out. My neighbor did that....and those easy-outs are hardened steel. He was in big trouble after that.....
Theres no locktite on this one. My only worry is that its real small, only 6mm so drilling the hole might take some serious skills on my part. Gotta try though right? It's not messing anything up right now, but t'would be nice to gank it outta there
