tv in headrest how 2 install?
Old Aug 16, 2002 | 10:56 PM
max1ma97se's Avatar
hey i was wondering how do you put tv's in your headrest? if anyone has done it themself and got directions. im thinkin about puttin 2 7 inch wodescreens is that too big? also how woul you run the wire cleanly ?
Old Aug 17, 2002 | 12:37 AM
chinaonnitrous1's Avatar
Re: tv in headrest how 2 install?
thats gonna be a little large especially for the 4th gen headrests..more like 5"
Old Aug 17, 2002 | 08:29 AM
wope's Avatar
7" and 6.8" fit fine in 4th gen headrests.. and no offense but i wouldnt try doing this alone if its your first time and you're reading directions online. you'll probably end up with messd up headrests
Old Aug 17, 2002 | 08:32 AM
wope's Avatar
and the wiring you'll have to run through the seat and make a tiny hole for it to come out at the top where the headrest usualy sits
Old Aug 17, 2002 | 11:00 AM
phatmax95's Avatar
I have never seen a 7" in the headrest, just 5's.. anybody have any pictures?
Old Aug 17, 2002 | 06:52 PM
vabeachmax's Avatar
Its not that hard to do. As long as you have some sort of knowledge about electrical stuff. I just put in two 5 inch tv's last weekend, and was surprised how easy it was. I would show pics but I don't have a digital camera. Just "search" for directions, thats how I figured out how to do it.
-Tom
Old Aug 17, 2002 | 07:08 PM
metallic97gxe's Avatar
Master Will
wiring them up will not be hard the "hard" part is installing them in the headrests in a good clean way...and not mess up the headrest...I was scared to do it so I jsut did a 7" wide scren fold-down instead
Old Aug 18, 2002 | 12:50 AM
N34JZ's Avatar
Needs non-Maxima Friends
Its not too hard
a little trick I use (and Ive done a few installs, including mine)
use some of the foam you cut out or tissues to beef up the edges so that the clamshell or headrest trim rests flat against the headrests, because sometimes the trim is flat and the headrests curves. It looks alot better and clean.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
carid
Sep 17, 2015 05:00 AM
2kmaximel
Sep 16, 2015 03:19 PM
